l2501 bushhogging questions
   / l2501 bushhogging questions #31
On most bushhogs, the tail wheel can be flipped up, and you conteol the angle with the 3 point arms. So, yes, call rental folks for sure; but that doesnt get your time back; it might be better to go ahead and flip the tail wheel up, adjust the 3 point to level, 3 inches off the round, and roll
   / l2501 bushhogging questions #32
I hate to get spanked, but wth.....I have for years only used a cutter at 1500 rpms. figured i was being easy on my engine. SO, what is "correct" PTO rpm - 540
Your machine will have a mark on the tachometer indicating what engine RPMs produce 540 pto rpms.
Good!
Bad! -- Tell them to bring over one that works and a guy to check it out before he leaves.
Front Range Kubota in FOuntain. They will hear from me tomorrow at 0800.
All the safety devices on this unit have been disconnected.
I did what you suggested. Though mostly level ground, very uneven surface. About two acres was all I could stand and still a very ugly cut.
   / l2501 bushhogging questions #35
Unfortunately this is costing you TIME!
I'd tell the rental company (Front Range Kubota in Fountain, CO) you want a unit that WORKS! To bring you another one ASAP!
And a 50% discount for what you paid, for the time and hassle you've put into diagnosis of there broken equipment!
Front Range is coming to pick up the junk, no rental fee, but has no other equipment to offer. Guess i will just enjoy the scenery.
   / l2501 bushhogging questions #37
Is there somewhere else you can an rent from?
I see there are a couple of Home Depot's in Colorado Springs near by ... They have a rental center ... I know they usually have TLB's, but may have a tractor and brush hog ...
Or just get another cup of coffee! ☕ :)
2024 8x22 Enclosed Trailer (A57453)
2024 8x22 Enclosed...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2008 FORD F-650 SUPER DUTY (A58214)
2008 FORD F-650...
