Todays shop time.
/ Todays shop time. #101
It has been my experience with bulbs in enclosed spaces but found that the clear not frosted bulbs lasted longer. I still hope it works for you great idea.
/ Todays shop time. #102
I will experiment with clear vs frosted re: lifespan.
Last night's low temps still froze both buckets, will try 100w bulb next, and used carpet padding insulation wrapping bucket/holder.
/ Todays shop time. #103
Are they protected from the wind? Makes a huge difference IME.
/ Todays shop time. #104
You might try a bucket deicer (Allied Precision Ind DT250 250-Watt Aluminum Bucket and Utility De-Icer) . Heat transfer from the metal over the light bulb to the bottom of a plastic bucket might not be enough to keep the bucket from freezing. If you build an insulated box that the bucket will sit in and a good seal at the top of the box and bucket the light bulb might work. Need to keep all of the heat from the light bulb keeping the water bucket warm. That said I think the bucket deicer is the better option.
/ Todays shop time. #106
Years ago my father in law cut the legs off this nice old cherry table. All different lengths and angles. Unusable. It was recently given to my wife so I trimmed legs so it is steady. image-3955223133.jpg
/ Todays shop time. #109
I have not been doing anything as cool as the projects most of you are working on. When I built my barn/shop I wanted it so I could get to all my equipment without having to move anything out of the way. So far this is it.
I have some other stuff on the other side of the barn that I can also just hook up. It all seems simple, but hooking everything up moving it around and out of the way takes a lot of time.
I am working on a hitch for my drill seeder but I'm not done yet.
/ Todays shop time. #110
Okay for those of you that saw my material storage cart back in post #56, I finally finished the mod to add larger (8in) pneumatic wheels. I slimed them, welded them to a plate and bolted them to the cart, widened the footprint some and realized I have more storage space underneath due to increased ground clearance, for long metal sections. So I welded up a large U bracket on both ends and now I can store several 10ft tubes, channels, L's etc. I like it!
The wheels work better for rolling over rough ground but they take more to get them to swivel. An improvement but not perfect. The plates extend out a bit now and will allow future mods/additions! Need a remote and power steering. :D
/ Todays shop time. #111
View attachment 492469 View attachment 492470
The wheel work better for rolling over rough ground but they take more to get them to swivel. An improvement but not perfect. Need a remote and power steering. :D
Hmmm.... one of those powered trailer ball movers spark some ideas?
Looks good. Great work and ideas.
/ Todays shop time. #112
I built a "winter time" hitch for my truck when plowing as I seem to do a lot at night and always needs to pull someone out . I wired the lights into a 7 way plug so they come on whenever I put my truck in reverse .
/ Todays shop time. #115
With my luck I'd have those lights knocked off in a snow bank my first night out. The light is gonna be really nice though! :thumbsup:
/ Todays shop time. #116
nothing worse than trying to back up when you can't see, and Andy you are going to see really well now.
And maybe not back into a mailbox now...as I have. Really nice job. Plug and play.
Necessity is the mother of invention they say
/ Todays shop time.
I built and installed a light mount for my lathe. That's been a needed improvement for years.IMG_8967.JPG
/ Todays shop time. #119
I built and installed a light mount for my lathe. That's been a needed improvement for years.View attachment 494694
Funny... I just did something similar... finally strapped an old fluorescent 'trouble' light that I wasn't using to my 20T shop press. I recently built a press brake from Swag Offroad kit and realized I needed better light to see my marks.
/ Todays shop time. #120
I thought there would be a lot more posting on this thread with the holidays but maybe too many of you like me are finding your shop just way too cold for shop time?
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
CAT 416B Front Loader Bucket (A68134)
CAT 416B Front...
2016 Ford Escape SE SUV (A66738)
2016 Ford Escape...
2014 FORD TRANSIT CONNECT VAN (A66091)
2014 FORD TRANSIT...
Flail Mower
Flail Mower
