To Toothbar or Not
/ To Toothbar or Not #21
For trees under 6" in diameter, I am able to dig them out with my (homemade) toothbar on my FEL by ramming the toothbar into the roots and ripping them out. It's more fun than using the backhoe. /forums/images/graemlins/grin.gif
/ To Toothbar or Not #22
A toothbar will dig out small trees ok. I have a BH as well but used the toothbar to dig out 30 or so 1-4" trees. Just get a tooth on/under it and curl the bucket to pop them out.
While you could dig out a sizeable tree with a toothbar I would not generally recomend it. If you just had one or two trees and thats your only resource then go for it. However it will be slow, messy and hard on the loader.
For general digging the toothbar will be noticeably better than a flat edge. You can also scoop/rake up brush/trash easier with much less dirt. Bottom line is that what your doing now will be easier with a toothbar. However I'd look into renting an excavator as the primary means of stump removal.
/ To Toothbar or Not #23
Wish we had so much sand to play in! The earth is much harder on machines in the Northeast. Endless rocks, heavy clay and wet conditions.
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
MACDON FD235 - 35' DRAPER HEAD (A64278)
MACDON FD235 - 35'...
2015 Ford Transit Connect Cargo Van (A64556)
2015 Ford Transit...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Turtle Statue (A64557)
