Tire scraper?
/ Tire scraper? #1
catdozer
Platinum Member
john deere
Well i now have a large loader tire that blew out on us and now going to use that tire to make a tire scraper. Its a 23.5-25 bias tire. Im going to make pushable with a skidsteer and pullable with a 3 point. Looking for ideas on their frame ive seen a few online but seeing if anyone else uses them. Mostly they are used for manure but i was thinking it would be good for snow and cleaning up slop on some roads
/ Tire scraper? #2
If you cut the sidewalls off, then you can unroll the tread for your scaper. Then it could be attached to any straight blade, or even a straight blade with rounded corners.
Using Circumference = πD, you actually can make a pretty long strip.
/ Tire scraper?
Well im thinking of cutting it in half to have two scrapers, then cut one side sidewall off to scrape and keep it rounded to collect. Heres a few pictures im thinking about doing.
/ Tire scraper?
Pictures
/ Tire scraper? #5
I'm a pretty handy guy, and I can do just about anything out in the garage, but, HOW IN THE **** DID YOU CUT THAT TIRE???!!!
/ Tire scraper? #7
A reciprocating saw would do it.
/ Tire scraper?
Reciprocating saw or I've seen people use a chainsaw with an old chain.
/ Tire scraper? #11
I use one of those oscillating multi-tools for stall mats and snow blade deflectors.
Bad Boy MZ Rambler Zero Turn Mower (A64047)
Bad Boy MZ Rambler...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2017 FORD F-250(INOPERABLE) (A63569)
2017 FORD...
2021 KUBOTA SVL75-2 SKID STEER (A64279)
2021 KUBOTA...
F-150 4WD (A63689)
F-150 4WD (A63689)
2019 BOBCAT T740 TRACK SKID STEER (A63569)
2019 BOBCAT T740...
