Tire scraper?
/ Tire scraper? #1
catdozer
john deere
Well i now have a large loader tire that blew out on us and now going to use that tire to make a tire scraper. Its a 23.5-25 bias tire. Im going to make pushable with a skidsteer and pullable with a 3 point. Looking for ideas on their frame ive seen a few online but seeing if anyone else uses them. Mostly they are used for manure but i was thinking it would be good for snow and cleaning up slop on some roads
/ Tire scraper? #2
If you cut the sidewalls off, then you can unroll the tread for your scaper. Then it could be attached to any straight blade, or even a straight blade with rounded corners.
Using Circumference = πD, you actually can make a pretty long strip.
/ Tire scraper?
Well im thinking of cutting it in half to have two scrapers, then cut one side sidewall off to scrape and keep it rounded to collect. Heres a few pictures im thinking about doing.
/ Tire scraper?
Pictures
/ Tire scraper? #5
I'm a pretty handy guy, and I can do just about anything out in the garage, but, HOW IN THE **** DID YOU CUT THAT TIRE???!!!
/ Tire scraper? #7
A reciprocating saw would do it.
/ Tire scraper?
Reciprocating saw or I've seen people use a chainsaw with an old chain.
Kubota M5-111 (A53317)
Madvac CS500 Sweeper (A61166)
Madvac CS500...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A61568)
2012 Ford F-750...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
