Tires tire question
/ tire question #1
rbig
Just to review my thoughts....
My CC will be used to put boats and other trailers on the front of the tractor.
I've used 2 ply tires, but not that sure how much loading they'll take. Would 4 ply be better, loadwise? Or does it really matter?
/ tire question #2
I'm a little lost but if you are doing loader work and having tire problems often a heavier tire will help prevent premature tire failure.
/ tire question #3
If you have been using 2 ply, and not problems, stick with them. The loading for the tires should be embossed in the sides of the tire.
If it ain't broke.... :D
/ tire question
My big question is whether or not ply rating is a load factor. It might control other tire factors. I was wondering if it is load rated or not.
/ tire question #5
That I don't know for sure. The loading is more to do with the sidewalls, on cars and truck I think they are letter coded. But it does make sense that a 6 ply tire would probably have a higher load rating than a 2 ply.
/ tire question #6
I do know the snowblower I mount on the front of my Cub weighs close to 300 pounds, I need to keep a little extra air in the tires when the blower is on.
That's probably close to the tongue weight you're looking at?
Curt
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
