Tire Failures
/ Tire Failures #21
Nice catch ... I think, it's an Indian arrowhead. :laughing:
Yep; maybe I should put it on eBay or something.:laughing:
/ Tire Failures #22
Actually, you were fairly lucky, aside from the tires being foam filled.
I was hogging for the local recreation site. I was in a field adjacent to a residence, when a piece of steel went through the inside of the tractor tire. I was made aware of the situation, by the noise of the steel hitting the fender on every revolution and the calcium squirting on my leg. I don't want that to happen again. It wasn't cheap and those filled tires are "unruly and heavy". :mad:
/ Tire Failures #23
Did you shred the metal post that came from?:confused2:
/ Tire Failures #24
Same things happened to our Case CX80 and patched them several times before we had to buy new tires. We spent several thousand dollars on four new tires and a year later the tractor went toes up and got just a couple thousand more out of it than we paid for the tires.
We use to wrestle those big tires too, but we now just call a service truck out to the field.
/ Tire Failures #25
Sure did, I am going to have to hunt it down as I hit stuff more than once, so there are a few spots I am going to check when I finish. I have hit a set of motorcycle ramps once and a few other things.:eek:
/ Tire Failures #26
I had mine foam a couple of years ago. I'd get flats and role offs. Since foamed nothing but happy acres around here. I'd do it again in a heartbeat.
CAT 930M (A58214)
CAT 930M (A58214)
INSPECTION (A61166)
INSPECTION (A61166)
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 International WorkStar 7400 Lely 4,500 Gallon T/A Septic Wet Vacuum Truck (A59230)
2018 International...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
