Tire Failures
/ Tire Failures #21
Nice catch ... I think, it's an Indian arrowhead. :laughing:
Yep; maybe I should put it on eBay or something.:laughing:
/ Tire Failures #22
Actually, you were fairly lucky, aside from the tires being foam filled.
I was hogging for the local recreation site. I was in a field adjacent to a residence, when a piece of steel went through the inside of the tractor tire. I was made aware of the situation, by the noise of the steel hitting the fender on every revolution and the calcium squirting on my leg. I don't want that to happen again. It wasn't cheap and those filled tires are "unruly and heavy". :mad:
/ Tire Failures #23
Did you shred the metal post that came from?:confused2:
/ Tire Failures #24
Same things happened to our Case CX80 and patched them several times before we had to buy new tires. We spent several thousand dollars on four new tires and a year later the tractor went toes up and got just a couple thousand more out of it than we paid for the tires.
We use to wrestle those big tires too, but we now just call a service truck out to the field.
/ Tire Failures #25
Sure did, I am going to have to hunt it down as I hit stuff more than once, so there are a few spots I am going to check when I finish. I have hit a set of motorcycle ramps once and a few other things.:eek:
/ Tire Failures #26
I had mine foam a couple of years ago. I'd get flats and role offs. Since foamed nothing but happy acres around here. I'd do it again in a heartbeat.
2025 Wolverine PFA-11-3300G 48in. Hydraulic Forks and Frame Skid Steer Attachment (A59228)
2025 Wolverine...
1995 Peterbilt 379 Tri-Axle Dump Truck (A59230)
1995 Peterbilt 379...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A59230)
2013 Chevrolet...
