Loaded Tires weeping
/ Loaded Tires weeping #11
I can't think of the magic words to search for, but there is a valve stem that you can insert from the "outside" and no need to break the bead ... Maybe someone will chime in with the brand ... Or I'll remember!
@ditzel: about how long did this process take you?
I have the right rear on my Mahindra 2645Cab weeping; i think it is coming out the valve stem, which I heard happens as the beet juice interacts with the rubber gasket material used on the metal valve stems.
Took me a few hours, but that's because I cleaned up, primed and painted the rims.
/ Loaded Tires weeping #14
You should be able to remove the outer portion of the valve stem and just replace that.
/ Loaded Tires weeping #15
I noticed around the bead of my tire, that I am assuming it is my plumbing antifreeze is weeping out. Not dripping out, just a weep. Enough to cause a slight bulge at the bottom of the tire from it sitting. Managed to get it into the garage last night, but that's as far as I got. Have the valve stem at the top of the tire, going to top up with air and hope the problem fixes itself. Was hoping it was just because of the temperature changes recently. One can hope.
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
14in Digging Tooth Bucket Excavator Attachment (A60352)
14in Digging Tooth...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
