tire chains.
/ tire chains. #1
gravelman
Platinum Member
NH
Kubota 2650
i have a set of St Pierre roller snow chains on turf tires...a small tractor. They continue to twist and will not stay in place. Tighteners are used but they are designed to roll so getting them too tight is not good. Any suggestions or others that may have encountered this thanks much
/ tire chains. #2
Sounds like the cross chains are too short.
/ tire chains. #3
Also when mounting your chains keep the side chains the same length,
if one side is longer then the other they will tend to walk off the tires.
/ tire chains.
ok on this..i will check both..thank you
(4) COLEMAN 60 QUART COOLERS (A64281)
(4) COLEMAN 60...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
AgCo Console 1 Monitor (A63117)
AgCo Console 1...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2017 FREIGHTLINER CASCADIA  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 FREIGHTLINER...
