tire chains.
/ tire chains. #1
gravelman
Platinum Member
NH
Kubota 2650
i have a set of St Pierre roller snow chains on turf tires...a small tractor. They continue to twist and will not stay in place. Tighteners are used but they are designed to roll so getting them too tight is not good. Any suggestions or others that may have encountered this thanks much
/ tire chains. #2
Sounds like the cross chains are too short.
/ tire chains. #3
Also when mounting your chains keep the side chains the same length,
if one side is longer then the other they will tend to walk off the tires.
/ tire chains.
ok on this..i will check both..thank you
