Tire Chains
/ Tire Chains #41
Okay, I am looking to buy chains, but do I really need tensioners? Can't I just use bungee cords or something? I am cheap, but practical if tensioners are definitely the way to go. Thanks for any help. Sorry to steal the thread!
/ Tire Chains #42
I have had excellent luck using the good old black rubber bungy cords and a metal ring from the hardware store to loop them through.
fellas, any answer to my last questions on page 4?
/ Tire Chains #43
Bungees work fine...
I have the tensioners now, but I used bungees last year.
/ Tire Chains #44
I don't use tensioners at all on my Kubota L3400 with R1's. If the chains are the right size they won't slap, and mine are run LOOSE, as suggested by the manufacturer. I started with about 2-3 inches of clearance, and other than an occasional slap the first year until I got the adjustment right, they've been fine.
Tellefsdal recommends that you should be able to get a clenched fist between the side chain and the tire, and that the whole chain should rotate around the tire about a foot for every km you drive.
Sean
/ Tire Chains #45
How are those chains for bumpy ride. I've goy V-bar ladder on the front and they are a killer on the frozen drive.
/ Tire Chains #46
If you mean mine, they're quite smooth. That's one of the benefits of having them loose, they can move around a bit and not create a high spot tight against the tire. I run on pavement a bit from one house to another at full speed, and they're not much worse than bare tires.
Sean
/ Tire Chains #47
Sean,
Do you have those on the front as well? And where did you get them?
/ Tire Chains #48
I only have them on the rear, other than a tendency to sideslip a bit when plowing with the rear blade angled, the tractor really doesn't need front chains. Being able to steer with brakes if I have to helps.
I got them from Nova International, my local Kubota dealer. They're made by Tellefsdal (Norwegian), and Aquiline makes or sells a chain called the Talon that's very similar.
Sean
36' GOOSENECK LIVESTOCK TRAILER (A63291)
36' GOOSENECK...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
