Tire Chains
/ Tire Chains #41
Okay, I am looking to buy chains, but do I really need tensioners? Can't I just use bungee cords or something? I am cheap, but practical if tensioners are definitely the way to go. Thanks for any help. Sorry to steal the thread!
/ Tire Chains #42
I have had excellent luck using the good old black rubber bungy cords and a metal ring from the hardware store to loop them through.
fellas, any answer to my last questions on page 4?
/ Tire Chains #43
Bungees work fine...
I have the tensioners now, but I used bungees last year.
/ Tire Chains #44
I don't use tensioners at all on my Kubota L3400 with R1's. If the chains are the right size they won't slap, and mine are run LOOSE, as suggested by the manufacturer. I started with about 2-3 inches of clearance, and other than an occasional slap the first year until I got the adjustment right, they've been fine.
Tellefsdal recommends that you should be able to get a clenched fist between the side chain and the tire, and that the whole chain should rotate around the tire about a foot for every km you drive.
Sean
/ Tire Chains #45
How are those chains for bumpy ride. I've goy V-bar ladder on the front and they are a killer on the frozen drive.
/ Tire Chains #46
If you mean mine, they're quite smooth. That's one of the benefits of having them loose, they can move around a bit and not create a high spot tight against the tire. I run on pavement a bit from one house to another at full speed, and they're not much worse than bare tires.
Sean
/ Tire Chains #47
Sean,
Do you have those on the front as well? And where did you get them?
/ Tire Chains #48
I only have them on the rear, other than a tendency to sideslip a bit when plowing with the rear blade angled, the tractor really doesn't need front chains. Being able to steer with brakes if I have to helps.
I got them from Nova International, my local Kubota dealer. They're made by Tellefsdal (Norwegian), and Aquiline makes or sells a chain called the Talon that's very similar.
Sean
DEUTZ ENGINE (A63569)
207276 (A52708)
207276 (A52708)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
JCT Skid Steer Tree Puller (A64047)
JCT Skid Steer...
KENWORTH CAB AND HOOD (A63569)
KENWORTH CAB AND...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
