Tire Chains
/ Tire Chains
How well do you think those horse mats will hold up? I'm thinking of finding some old carpet from an installer.
/ Tire Chains #22
They will hold up just fine. We have been using them for the horses indoors and out for many years. They are made of rubber and are 3'x4' and about 3/4" thick. They weigh 50 pounds each. My tires will give up before these horse mats.
/ Tire Chains #23
Do you use them on flat ground or do you have some hills? I would say they are the ones I'm leaning towards. I think both of the Aquiline types have the advantage of having two strips of chains going around the tread of the tire where as the duo-grip and the double rings have sections where there isn't any chain. It may not make a difference but like I said I don't want a chain that's only touching a very limited amount of lug. But they do cost more.
The duo grip chains work well, but they ride like a baby carriage with square wheels on any kind of pavement, or hard surface........ I don't like mine except in the woods.
/ Tire Chains #24
I too am looking to put chains on my low clearance Mahindra. Any idea how much side clearance is required for the MPCs? The local guy told me 2.5 to 3 inches. I'm wondering if he's being conservative.
/ Tire Chains #25
I run 4-link v-bar chains on my front and rear R-4 tires. As you can see in the pic I put some sheets of OSB down to protect the cement floor. No problem using the snow blower on icy, sloping driveway or road. Now if we ever get some snow!!!
/ Tire Chains
One of the local dealers had a section of the MPC chain. If you tighten snugly I bet you could get away with an inch of clearance on the top and maybe two on the side.
/ Tire Chains #27
I asked several local fabricators for price to make 1-1/2 inch spaces since I only have 1-1/4 inch of side clearance. $500! I wonder if there's a different way.
/ Tire Chains #28
As it turns out, the skidsteer hub is the same as the rear of the Mahindra 3535. Just ordered two 2" spacers for $210. Nice alternative to custom made.
/ Tire Chains #29
I have a 4035 with R-4s. Sold my old chains because I have vey little clearence to the fenders. If I think I need something I'm going to order those carbide studs that you screw in.
Dan.
/ Tire Chains #30
Yeah, I thought about that but I was concerned that I wouldn't get the snow traction I need to climb the hill on my driveway.
/ Tire Chains #31
I am running these chains with 2.5" clearance. It's close. About 1/4" left for clearance. These chains have to be tight and tucked. I safety wire everything that can flop around and catch a fender. These are heavy duty and aggressive chains:
/ Tire Chains #32
One more thing I forgot. These pics are a couple of years old and every time I post these pics my good friends at TBN tell me turn the hooks around on the chain tensioners so they don't damage my tires. They're turned around now guys. And thanks for the good advice.
/ Tire Chains #33
Those are nice looking chains. Based on your clearances I should be fine now that I've found some spacers.
/ Tire Chains #34
Dan.
I was hoping to put chains on my 4035 but I guess I should rethink that idea.
/ Tire Chains #35
I was looking at my 3535 and it looks like the fenders have additional holes by which you could actually raise the fenders. Not sure if you could do that with the 4035. Add some wheel spacers and you'd be in business.
/ Tire Chains #37
I will look at mine and see if that is an option. Thank you for the pictures.
/ Tire Chains #38
I use chain tensioners because the clearance is marginal.
/ Tire Chains #40
I have the MPC chains. They work great on both concrete (no chipping) and gravel.
three questions:
1. Do they make the MPCs small enough to fit the front tires?
2. Do they really not chip pavement or concrete?
3. what sites have guys had luck ordering from?
SHOP MADE 36' T/A GOOSENECK SHOWER/EYE WASHTRAILER (A63569)
SHOP MADE 36' T/A...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
Bobcat 60� Tine Rake (A64047)
Bobcat 60� Tine...
445 (A63290)
445 (A63290)
2021 CAM P4EC16  16ft Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
2006 John Deere 1600 Turf Mower (A63116)
2006 John Deere...
