Tires tire chains/wheelbase extender
/ tire chains/wheelbase extender #1
otis_ofnh
I am trying to install tire chains on my Kioti LB1914. It appears that I will need to extend the wheelbase by 3/4" each side. Is there a aftermarket part to accomplish this.
/ tire chains/wheelbase extender #2
Why do you need to extend your wheel base? /forums/images/graemlins/blush.gif
/ tire chains/wheelbase extender #3
<font color="blue"> extend the wheelbase by 3/4" </font>
The wheelbase is determined by the location of the axles, which are fixed. Do you mean increase the tread width?
/ tire chains/wheelbase extender #4
If the tread width is what needs to be increased, perhaps reversing the rims would accomplish that....?
/ tire chains/wheelbase extender #5
I think his tires are to wide(like turfs) and is looking for more clearance to put his chains on so they don't hit.I've seen people on the the Kubota boards with the smaller makes with turf tires and have little clearance to put chains on.They mentioned something about wheel spacer kits to move the wheels out more to gain clearance for chains.Is this what your looking for?
A spacer kit is exactly what I think I need, my dealer was unaware of a kioti part for this, so now I am looking for other options, including making something myself. I'd rather not if I can buy something to fit at a resonable price. I can't be the first LB1914 owner to run into this. Thanks.
Yes, so that the chains don't hit the fender.
The rims are already positioned at max.
The chains if installed as is will rub on the fender.
/ tire chains/wheelbase extender #10
I suggest you first try your Kioti dealer. They may be able to help you out.
You might also try a Hot Rod parts distributor or shop that specializes in high performance vehicles (sometimes bigger tires on a rod or customized car require the wheel spaced out to accept bigger tires). You'll want to know what the bolt circle diameter is as well as any cut outs for the hub.
If that doesn't work, you may have to make (or have made) your own.
It shouldn't be too difficult for a machine shop to make spacers. If your local high school has a Vo-Tech dept., they might help you out, as long as you provide the materials.
I suggest you have them made from Aluminum.
Now, if your wheel hubs have studs, you will probably have to get longer ones installed. If your rear wheels are held on by bolts...well, that'll be easier. Just make sure you get the right threads. More then likely, they'll be a metric thread. They could be a more specialized thread (JIS or something), but that's really unlikely.
If you use a spacer (especially if you use an aluminum spacer), make sure you use plenty on anti-seize compound on the mating surfaces. Otherwise, you may end up with corrosion.
By the way, I think you want to use the term track, rather then wheel base. The wheel base is the distance between the front and rear axles. Track is the distance between the wheels on the same axle (normally measured from wheel center to wheel center, if I recall).
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2025 32in Bucket Mini Excavator Attachment (A66734)
2025 32in Bucket...
2016 Chevrolet Tahoe SUV (A66738)
2016 Chevrolet...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2013 C&M TRAILER CHLORINE DIOXIDE MANIFOLD TRAILER (A67714)
2013 C&M TRAILER...
