Tire chains, again!
/ Tire chains, again! #11
Thanks pete i will check into a little less aggressive chain for my driveway i will check windy ringe in N.H it's not that far
Thanks again
EDT
Well I checked with Ken Jones Tire in Pa., their version is called either single or double diamond chains, which refers to either 1 or 2 studs welded to the links. Single diamonds are approximately $590- $600 for the 420/70-24 R4's that I have. In light of the comments fielded by gerard and Boondox, I think that I will be going with the regular duo- grips and my soon to be loaded rear tires. If I need some additional weight, I have some ideas for a couple of different ways to add weight to my rear blade. Thanks Boondox, Thomas, Kodiak, and gerard.... All I need to do is figure out how to persuade the wife how nice a new L series Kubota would be in our garage. ( The 3010 hst only has 105 hours on it now).
/ Tire chains, again! #13
I know this is a different animal, but for non-ice chains I've seen prices no less than $200 running up to almost $400 for my Deere 4200 industrials. That has kept me from owning a set thus far (well, that and the super mild winter last year). I don't expect my second winter of tractor ownership to be as mild as the first so I'm thinking of chains again.
Just yesterday I was out at a local semi truck service facility (Fleet Service, where another TBN'er works) and wandered through the parts department while they were preparing my bill. I saw chains for semi tractors there. I asked and was told they were just over $100 per pair. That sounded pretty cheap to me.
I've not seen them on anything and don't know how they're configured but I'm guessing they're probably some simple ladder style. The size would seem to be close enough to work with some trimming which I'd be happy to do for $200-$300 per chain. /w3tcompact/icons/smile.gif
I'm wondering if anyone else has tried or even considered trying these on a (farm) tractor. Would they work with the type of tire I have? If they would work, they'd be a lot less expensive than what I've seen.
/ Tire chains, again! #14
All things being equal (ie: same grade, link style, etc), there's no reason not to save yourself the money and buy truck chains and modify them. Basically, if it works, no reason not to.
Sometimes the difference in prices between things is just dependent on where you get them or who you know.
/ Tire chains, again! #15
Absolutely check around! There's a place down the road in Barre VT called McLean's that does heavy work for truckers. They custom make chains for very reasonable rates. If I didn't want the carbide spikes I would definitely have bought chains there
Pete
/ Tire chains, again! #16
If it is just a ladder type chain you might need to add an extra cross link. If you don't you may have trouble with the links falling into the voids of the tire tread. They won't all fall in but you might spin till the link comes around that isn't in the void. Make sure you can get your hands on some chian pliers. They will save you a lot of sweat, blood, and a few new words.
/ Tire chains, again! #18
Yes, truck tire chains work well for small tractors. I put a set of Peerless truck tire chains from local TSC store on my 4100 with Turfs. Perfect combination. Ride is still OK, traction is excellent. Price was well under $100 for the rear set. TSC orders from Peerless, and they make virtually every size. Take your tire measurements to the TSC store in both metric and inch numbers to make the process easier. Mine are 4-link chains and work great on turfs, but if using on R4 tires you may want 2-link.
/ Tire chains, again! #19
I have R4's on my Cub, and I use old truck tire chains that I got for nothing from the guys in our town garage. They were glad to get rid of them... I used a pair of chain pliers to make them to the size I needed for my tires, and they work great. Took me about 3 hours on a Sat morning to make up chains for all 4 tires (and as a side benefit, I have lot's of spare parts /w3tcompact/icons/smile.gif). BTW, I have yet to use the ones for the rear tires. The chains in the front give me all the extra winter traction I need, and they also allow me to steer much better when my driveway is snow and ice covered. I offer this as an alternative to buying new chains. This worked for me, and no $$.
Corm
/ Tire chains, again! #20
The truck tires or the Deere tires?
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2013 Ford E-350 Cargo Van (A59230)
2013 Ford E-350...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
