Chains Tire Chain Size Help
/ Tire Chain Size Help #1
sdboers
Oxford Station, Ontario
Mahindra 4025 4wd
Hey there,
Been thinking of putting chains on my rear tires for ages now - just came across a local deal, but I'm unsure on sizing...
My tires are 16.9x24 Industrial.
The chains are advertised as 11 feet long and 2 feet wide - they are a simple ladder style.
Will these fit close enough to try to make it work? Price is $275 Canadian.
Sean.
/ Tire Chain Size Help #2
Hey there,
Sean.
Those chains will be too long BUT they can be cut down to work.
I can't find any reference anywhere that would actually tell me what size (length and width) is correct. I can plug my tire size in and get models to buy - but not an actual size.
How much too big are they? If they are too long - can they simply be overlapped?
Sean.
/ Tire Chain Size Help #4
Sean.
I had the same problem trying to find chains for mine.
Ended up buying a set and they fit my MF50. Ran them till the 50 died & just cut them down for the 1510.
I have no idea how much too long they will be.
Yes you MAY be able to overlap but it is easier to just cut them. If you need them restored in the future, just add a repair link.
/ Tire Chain Size Help #5
On this end of the country I called this outfit and told them my tire size and type. (36-14x15 turf) They do a lot of logging equipment chains and other off road equipment.
They made up a set of 2 link V bar ladder chains that fit well. Only problem I had was the sent 20 cross links per chain and they should have sent 21. I called again and they sent an extra cross link for both chains to fill the gap being one short left.
I have run loaded turf tires with ladder chains on a couple different tractors and they have work well.
44
/ Tire Chain Size Help #6
What's the simplest, easiest way to mount rear chains?
/ Tire Chain Size Help #7
Redfox2 - I've never found an EASY way. Jack up one rear tire at a time. Pull the chains over and tug, curse, pull, squeeze - then lock them off. Drive the tractor for 50 feet - if they are loose - do it all again.
OR - have your brother-in-law come over and instal them for you.
If you have heavy duty tractor chains - as I did - they are EXCEPTIONALLY heavy.
One of my happiest day was when I upgraded to my Kubota M6040 and NO LONGER needed chains.
/ Tire Chain Size Help #8
Easiest way to get an approximate length is to figure out where on the sidewall the side chains will be and multiply the diameter they will make by 3.14. It'll be approximate but it'll give you a rough idea...............Mike
/ Tire Chain Size Help #9
Forum- General Forums- Snow Removal -Mounting tire chains
I posted the thread Mounting tire chains in the snow removal forum.
It will show how I mount chains,
I am mounting on a larger tire then yours, the smallest that I have mounted chains on are 11.2-24's
I'm not sure how my method will work with the smaller tires, I think it would be good.
As a follow up - I did end up getting those chains. They were about 8 inches too long. I simply overlapped them and connected, then attached the slack with quick links. Used 3 bungee cords per side as tensioners and I'm off to the races.
/ Tire Chain Size Help #11
About those tire chains for my tractor . . . . .
It would seem simple enough, just jack up the rear end of the beast, drape the chains over the top of the tire, pull em snug, then hook the free ends together . . . right? Perhaps if I had ordered the machine with the ' Turf ' treads? These R-4 treads have lugs!
The tractor fenders over the top of the rear tires has too little clearance for me to reach over the top of the tire to spread the chains evenly, and there's a similar problem trying to pull the chains under the tires evenly toward joining the ends together.
Frustrated and angry I decided to take the tire & rim off the machine in order to gain some advantage in trying to wrap the chains evenly around the tire. Okay, modest success . . . then I hadda mount the thing back on to the tractor. By then I was cold, numb, and a bit overly unhappy. The rims mount by removable bolts, not on bolt studs like an automobile axle. It took a bit of fine tuning with the jack in order to get the axle at a close enough altitude that I could get a bolt lined up with the threaded receptacle for it . . and then I could get the other bolt holes lined up.
. . and I'm still NOT happy with the amount of slack in the chain ( we'll see how the bungee cords adjust when I'm able to drive the tractor a few feet ) . . .
But after 2 1/2 hours of freezing, pulling, tugging, down on my knees and back up again ( too many times to count ) I managed to get ONE set of chains mounted. It may be a couple days before I have the energy to tackle the other side. At least I now have a system worked out and I won't ( hopefully ) spend all the time it took me to arrive at the decision to take the wheel off for the first side.
Time for a couple aspirin, an Aleve, and a nap!
/ Tire Chain Size Help #13
Seems like tires are like jeans in that sizing is different everywhere. So frustrating
2024 GD Yatian LY05A Model T Replica Electric Cart (A61574)
2024 GD Yatian...
2017 Mack Semi (A64047)
2017 Mack Semi...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2022 John Deere DR16 Planter (A63111)
2022 John Deere...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
