Ballast Tire Ballast
/ Tire Ballast #11
The big problem I would have with methanol is that is is highly flammable and the flames are invisible. I really don't like the idea of having such a thing sloshing around in my tires.
I don't do a lot of heavy-duty loader work, but when I do I just always have an implement hanging off the back - either my finish mower (which stays on most of the summer) or my box blade. The 500-800lbs hanging off of the 3-point, which is a good couple feet further behind the center of gravity of the tractor than the rear wheels, seems to offer a pretty good ballast to the weight at the front.
/ Tire Ballast #12
As far as I know from experience and the recommendations several tractor manufactures is that the equilavent loading you need between tire loading, wheel weights and 3 pt hitch weight needs to be equal to the max amount you want to lift with the loader. The wheel weights and loading fluid are multipled by 1 and the 3 pt hitch weight is multiplied by 1.5 to account for the leverage effect. For example if you have 1000 lb wheel loading and 800 lbs of 3 pt hitch weight you can safely carry 1000 lb plus 1.5 x 800 or 2200 lbs with your loader. Many people on this board run and talk about improperly balasted tractors.
Andy
/ Tire Ballast #13
dry_creek_farm said:
Supposedly the anti-freeze will not attack the rubber or steel rim (cooling systems have rubber hoses and cast iron engine blocks) as long as you change out the mixture every 3-5 years.
Rather than change out the antifreeze you can additives to restore the corrosion resistance at any automotive store. Here's Antifreeze Recycling some interesting antifreeze info. MikeD74T
/ Tire Ballast #14
I just bought a L3400. I lifted a load of dirt at the dealer along with the rear tires. I added calcium. The dealer had tubes installed to protect the rims from the calcium. This made a big difference. :) I don't like having anything on the 3 point when I do bucket work. It is a clearance thing. Both tires filled with tubes was around $220.
/ Tire Ballast #15
2manyrocks said:
I asked my local coop about filling tires. They said they use methanol instead of antifreeze because it's not as bad for the environment when it finally leaks out.
Your comment got me thinking. Here is the skinny from the MSDS sheet:
Not as bad for the environment as I thought.
12. Ecological Information
Environmental Fate:
When released into the soil, this material is expected to readily biodegrade. When released into the soil, this material is expected to leach into groundwater. When released into water, this material is expected to readily biodegrade. When released into the air, this material is expected to be readily degraded by reaction with photochemically produced hydroxyl radicals. When released into the air, this material is expected to have a half-life between 1 and 10 days.
Environmental Toxicity:
No information found.
/ Tire Ballast #16
I've got the tires on my Montana filled with a 50/50 mixture of standard anti-freeze.
My dealer recommends inserting tubes prior to filling tires. His logic is that it is possible that a tire can be punctured without the tube being damaged (thereby retaining all fluid) and it is worth the $30 investment for the additional protection. Me thinks he may be right. Me knows he is a good salesman, however.
My understanding is that ethylene glycol (antifreeze) is risky should there be a spill, if small animals are around, as it is lethal in small amounts and they are attracted by the sweet taste. Windshield washer fluid (ethanol mix) appears to be a safer option.
/ Tire Ballast #17
I have unloaded tires on my Kubota L3830. I figured sooner or later I would puncture a tire or two and have a mess if they were loaded. I plug my own tires, (on my atv, cars, truck), and a plug would probably work on filled tires, providing you don't have inner tubes installed, though.
However...I always keep my box blade with extra weight on the 3 point, (800 lbs) or another implement attached and have wheel weights installed, (300 lbs). The combination of the two weight types works well for me and I can lift a full load all the way up in the 4in1. I keep about 40 psi in the front tires, and 8 psi in the R4 rears, (so the tire is not rounded and the whole tread lays fairly flat for max traction and wear).
Andy...That's a good tip...(The wheel weights and loading fluid are multipled by 1 and the 3 pt hitch weight is multiplied by 1.5 to account for the leverage effect). I did not know that...and thinking about it...seems absolutely correct. I know the bucket weight and cu/ft capacity and also a good estimate of the soil weight. It adds up pretty close in real life.
/ Tire Ballast #18
Hey RedBug where did you get the wheel weights?
RC
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2026 tilt trailer (A56859)
2026 tilt trailer...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
John Deere 50 (A60462)
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2017 FORD F-150 XL CREW CAB TRUCK (A59823)
2017 FORD F-150 XL...
