Grading Tips for grading driveway?
/ Tips for grading driveway? #21
I just redid my 600' driveway. I added #2 & minus gravel, spread where possible /forums/images/graemlins/wink.gif by the dump truck. I spread the rest with the FEL and back dragged with it too. Sure wish i had a box blade or york rake but the budget didn't allow.
The results were ok, some washboarding and a few thin spots. As a new tractor owner I found it hard not too dig in if I was going forward. Overall I am happy with the results, 2 loads of gravel and about 5 hours of fun left me with a surface i will be able to clear this winter once the rear snowblower gets delivered.
/ Tips for grading driveway? #22
What I struggle with is the dips & dives. When driving a vehicle over the driveway, it's fairly smooth but the vehicle's shocks keep getting a workout because of the driveway's high/low/high/low stature. I'm using a rear blade because I don't have a boxblade but have graded it a half dozen times and still can't seem to smoothen the dips & dives. If anyone has had this problem & found a "Fix", I sure would like to hear it.
Eric
/ Tips for grading driveway? #23
An adjustable rear tail wheel. Some of the better blade manufactures off them. I would like to add one to my blade, but I don't need it real bad.
/ Tips for grading driveway? #24
JerryG.....
Thanks for idea, actually I'm preparing to modify (minor) my blade for snow removal this winter & was thinking of skid shoes or caster so that it wouldn't dig in too much. How far back do they mount the wheels ?? Let me run something by you as well, this summer when a constuction crew was paving our road I noticed that the paving machine had "out-riggers" on both sides which I think were to help them keep things "level". I wondered if I were to do something like that it might help to keep things level better. Your Thoughts on this and the casters ??
/forums/images/graemlins/smile.gif Eric
/ Tips for grading driveway? #25
After reading my previous post, it seems like I'm only looking for input from Jerry; quite the contrary, anyone who has any ideas is definetly welcome to reply......
/ Tips for grading driveway? #26
Pine Ridge,
I do the same thing, but not with the rake reversed - hows that work out?
I can only think of when I back up a little on rubble with my rake and shoot forward (at me) at about mach 2! But now you got me curious......
/ Tips for grading driveway? #27
Using a landscape rake for finishing has been very useful to me. I turn it around and adjust the top link to keep the tines in a not-to-aggressive stance. I only want it to pull the high spots down into the low spots, and it does this pretty well.
Now, when I've had hard pack to deal with, I've broken it up with my box blade/rippers first, and leveled as best I can and then finish with the turned around rake. Gets it all really smooth and level. Having the top link adjusted just right is the trick. It may take some playing with until you get the results you wish. John
/ Tips for grading driveway? #28
I don't really think that wheels to the sides like outriggers would help. The reason a tail wheel about 3-4' back works is that it allows the blade to float by running on the ground that you have already bladed.
/ Tips for grading driveway? #29
Here is picture a tail-wheel like I was speaking about.
/ Tips for grading driveway? #30
Thanks for the pic because when you said tail wheel, I pictured 2 small 4" casters. I like that setup & think with that system you could finetune how agressive the blade is. Hmmmm, you've got me thinking.....
/ Tips for grading driveway? #31
To all:
I got some crushed limestone delivered yesterday, what they called 411. I had no problem spreading the 2B I put down two years ago, but this stuff is a different animal. After reading all the info here, am I to understand that after getting it *close* to how I want it, that I then go over it again with my landscape rake? It isn't bad now, but I too have the slight dips and rises from the back blade undulating in relation to the tractor.
Or, do I need to make a drag and angle it?
Thanks for clearing this up for me if you would.
/ Tips for grading driveway? #32
KC,
I'm in the same predicament as you except my driveway is way steep. I use a rear blade (heavy duty model) and still get washboarding. I set my crown angle by adjusting the one side of the 3 point up and down.
Anyway one of the locals with much more experience than myself suggested I use a york rake with wheels. He said backblading is an art and takes patience....I think he's right. The first time I used it my driveway looked like a crash site!
I'm gonna try the york in a couple of weeks and will report back.
Good Luck!
washoarding is caused by either wrong tilt angle and groudn speed. i used to have the same problem. i went online and downloaded a gravel road maintenace pdf and i found it to be very helpful, it shows the correct crown, where the tilt should be, how to seperate any larger rocks out if the road as your blading and much more, if any of this is helpful, your welcome. i have been doing the family road for several years now,
/ Tips for grading driveway? #33
I have a 1/4 mile of unfinished (not paved) road. Base is 3 inch and topped with 2-3 inches of concrete (finely chopped pieces less than 1/4 inch) dust (could also use 1/4 inch dirty stone dust). I use a rear blade turned backwards to loosen the material and get it "fluffed" up then go over it with a section of chain link fencing (6'x 6') to smooth out the ripples (also works well to level new lawn bases)
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
JCT 72" VIBRATORY ROLLER (A64281)
JCT 72" VIBRATORY...
John Deere XUV825E (A61307)
John Deere XUV825E...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
