Tipping butt pucker!!
/ Tipping butt pucker!! #1
DutchHenryBrown
Platinum Member
Tombstone, AT
Mahindra 5010
Yesterday I had been grading the dirt road out to the highway with the grader scraper and using the FEL to move dirt to some low spots. Came back to change over to the rock rake to clean up a bit. Not thinking because I had been using the FEL I took a big scoop of dirt for another low spot. Lucky for me I keep the bucket low to the ground when moving with it full. So I was going to drop the rock rake and use it on the way to the low spot. As soon as I dropped the rake and with the full bucket she nosed over lucky the bucket hit the ground and stopped the tip!! As soon as I pulled the rake back up she sat back down! Completely my fault didn't even think about the implement weight change out back! In the blink of an eye that fast I feel very lucky it could of been a lot worse. Like they say you can't fix STUPID!! Be safe when out and about.
/ Tipping butt pucker!! #2
Rear tires aren't loaded?
/ Tipping butt pucker!! #4
Get some wheel weights. :thumbsup:
1951_farmall_cub_farm_tractor_with_snow_blade_plow__wheel_weights_runs_good_9_lgw (Small).jpg
They even make weights that fit on the inside of the wheel.
/ Tipping butt pucker!! #10
I'm glad it worked out well.
I understand your pucker. :)
/ Tipping butt pucker!! #11
Aaron, great photo. The best photo I've ever saw showing the value of a ROPS. Looks like it's the only reason that tractor didn't go onto it's lid!!!
/ Tipping butt pucker!! #14
Thanks guys. Unfortunately I was not smart enough to be wearing the seat belt at the time (lesson learned). Fortunately God was watching over me. The tractor tipped ever so slowly and sits low enough that I had time to step/hop off and out of the way. Not a scratch on me or the tractor.
Here is a pic from another angle. I was able to attach a strap to the ROPS, and a come-a-long to the tree on the bank behind the tractor and easily tip it back over. I let it sit for awhile to give the fluids time to drain back to where they belong and it fired right up. Been running fine ever since.
/ Tipping butt pucker!! #15
Dang..Aaron,you gave me cold chills looking at that even way up here in the pucker brush w/20F.
Glad your still w/us.
/ Tipping butt pucker!! #16
Never had a issue with front tipping, in fact we used to see how long we could go on the front wheels with the loaders! Not good with our tractors but it still happens. Now Aaron's tip on it's side is what scares me. I tipped a skidder on it's side but it righted itself when I turned into the direction of the tip. [nice thing about articulating machines] Had to think about that for a minute or 2 before going back to work! CJ
/ Tipping butt pucker!! #17
I think what happened to you is the hazards of a BH on the back. Your boom was pointing straight back. So the high weight of the boom pulled the tractor over. I use my Brother's full sized hoe a lot in the timber. I'm very cautious about swinging the boom to the high side when on a side incline.
Did that ordeal make you feel a little stupid when it happened?? I have this vision of you standing there looking at the tractor and talking outloud to yourself about how stupid you were!!! No disrespect intended. :)
/ Tipping butt pucker!! #18
Mine is a Teeter-Totter! :D
/ Tipping butt pucker!! #19
Yes it did. :) Stupid for not wearing a seat belt, stupid for having the fel too high, stupid for not watching the left side of the machine (the front left tire climbed the bank and the fel full of dirt/rocks took me over), and stupid for operating the machine while alone on my property with the nearest family being an hour away.
/ Tipping butt pucker!! #20
95% of the time I'm alone when on my tractor. Help is 20 minutes away. That is,,,,, if I can get to my phone...... So, I'm very, very cautious. Always watching where all four tires are and where my load is. I am rarely surprised by something like that. I'll bet you keep closer watch on all that stuff now too!!!
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
ONAN 5000 GENSET EMERALD PLUS 50AMP (A64281)
ONAN 5000 GENSET...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2011 Blue Bird School Bus (A62613)
2011 Blue Bird...
2006 Freightliner M2 106 24ft. Box Truck (A61573)
2006 Freightliner...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
