Tipping butt pucker!!
/ Tipping butt pucker!! #41
I guess this is a little steeper than I should have been. As long as I was straight up or straight down the slopes it wasn't too scary.
/ Tipping butt pucker!! #42
What machine was it?
This is 30 degrees of body lean (sway bar disconnected) on a 27 degree slope.
/ Tipping butt pucker!! #43
It was in an IC-45 rubber tracked crawler
/ Tipping butt pucker!! #44
It's amazing how quickly it can happen. I've had several close calls doing snow removal getting off the edge of my road and having a tire go through the snow.
/ Tipping butt pucker!! #45
Thanks. That is a little larger than my wheeled dumper, but I haven't had it on any serious slopes.
/ Tipping butt pucker!! #46
I like that tilt meter. What kind is it?
/ Tipping butt pucker!! #47
Craftsman 3983 Magnetic Protractor. You manually rotate the dial until it shows level, then it points to the degree of the angle.
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
iDrive TDS-2010H...
2022 EZ-GO ELITE...
Military Transfer Cases (A64119)
Military Transfer...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
