Time for brakes?
/ Time for brakes? #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I hauled a half dozen pallets of sod to the next town over on my p/u-tag trailer this afternoon (Not a habit, but our road tractor was temporarily down).
I took it easy, but when I firmly applied brakes it seems like there was more shaking than stopping. Brakes seem just fine unloaded.
I was thinking rotors (4 of them:( ), but I dont know... shouldn't they be warped all the time?
/ Time for brakes? #2
Your rotors are probably just heat glazed and not warped, that would explain the shaking under load.
/ Time for brakes?
That's a new one to me. If I understand, this just happens if the brakes are hot? Is there a solution other than cool brakes?
/ Time for brakes? #4
I think its warped rotors. I did it before also. Had to pull a 10K trailer down a big hill with no trailer brakes.
Only fix is to have them turned and dont do that again. lol
Chris
/ Time for brakes? #5
Heat glazing results when an OEM pad is heated beyond standard use, the heat essentially melts the pad an rotor making them dinner plate smooth, slightly irregular and taking away a good portion of their stopping power. To fix this condition you should have the rotors turned(like diamond pilot said) and switch to a semi-ceramic pad, if your rotors are shot...shop aftermarket cross drilled ones that are designed for heavy use, I was a stubborn OEM guy for years till my son talked me into a front set on my tow rig and I realized the first time I applied the brakes how wrong I was all these years, as a bonus they were Less than OEM replacements.
/ Time for brakes? #6
I have resurfaced heat glazed brake pads with a wire brush in the angle grinder... Luckily they dont sell asbestos brake lining anymore these days ;)
/ Time for brakes? #7
Doesn't matter, you were wearing a dust mask anyway, RIGHT???
David from jax
/ Time for brakes? #9
Well, at least your feet didn't breathe in the fumes!!!
David from jax
/ Time for brakes? #10
I would look at the rear of the truck first. When you have no load the rear brakes do very little but once you put a load it down that's when you'll notice problems.
2020 Chevrolet Equinox SUV (A61574)
2020 Chevrolet...
LOOK! (A63111)
LOOK! (A63111)
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
Massey Ferguson 250 Tractor (A62613)
Massey Ferguson...
