Time for brakes?
/ Time for brakes? #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I hauled a half dozen pallets of sod to the next town over on my p/u-tag trailer this afternoon (Not a habit, but our road tractor was temporarily down).
I took it easy, but when I firmly applied brakes it seems like there was more shaking than stopping. Brakes seem just fine unloaded.
I was thinking rotors (4 of them:( ), but I dont know... shouldn't they be warped all the time?
/ Time for brakes? #2
Your rotors are probably just heat glazed and not warped, that would explain the shaking under load.
/ Time for brakes?
That's a new one to me. If I understand, this just happens if the brakes are hot? Is there a solution other than cool brakes?
/ Time for brakes? #4
I think its warped rotors. I did it before also. Had to pull a 10K trailer down a big hill with no trailer brakes.
Only fix is to have them turned and dont do that again. lol
Chris
/ Time for brakes? #5
Heat glazing results when an OEM pad is heated beyond standard use, the heat essentially melts the pad an rotor making them dinner plate smooth, slightly irregular and taking away a good portion of their stopping power. To fix this condition you should have the rotors turned(like diamond pilot said) and switch to a semi-ceramic pad, if your rotors are shot...shop aftermarket cross drilled ones that are designed for heavy use, I was a stubborn OEM guy for years till my son talked me into a front set on my tow rig and I realized the first time I applied the brakes how wrong I was all these years, as a bonus they were Less than OEM replacements.
/ Time for brakes? #6
I have resurfaced heat glazed brake pads with a wire brush in the angle grinder... Luckily they dont sell asbestos brake lining anymore these days ;)
/ Time for brakes? #7
Doesn't matter, you were wearing a dust mask anyway, RIGHT???
David from jax
/ Time for brakes? #9
Well, at least your feet didn't breathe in the fumes!!!
David from jax
/ Time for brakes? #10
I would look at the rear of the truck first. When you have no load the rear brakes do very little but once you put a load it down that's when you'll notice problems.
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
Brown 6' Tree Cutter (A64119)
Brown 6' Tree...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2021 Tesla Model Y Long Range AWD Sedan (A61574)
2021 Tesla Model Y...
iDrive TDS-2010H...
