Throttle stuck wide open
/ Throttle stuck wide open #1
Ed@richsq
John Deere 850
I bought a jd 850, knowing the accelerator needed fixing. When started it is wide open. The previous owner told me it's been sitting for 5 or more yrs. I paid 1500. But I'm needing advice
/ Throttle stuck wide open #2
Welcome to TBN.
Can you tell whether it is the linkage or the pump?
Did you take the linkage off of the pump and see if the pump would return to idle?
If so, did you try to move the throttle shaft on the pum?
/ Throttle stuck wide open #3
Welcome to TBN.
Try lube spray the pivot points than work throttle level by hand with engine off.
2012 Blue Bird School Bus (A61573)
2012 Blue Bird...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59912)
2025 ALCOM XPRESS...
80003CFL (A61568)
80003CFL (A61568)
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
SINGLE BOTTOM PLOW (A64280)
SINGLE BOTTOM PLOW...
