Throttle stuck wide open
/ Throttle stuck wide open #1
Ed@richsq
John Deere 850
I bought a jd 850, knowing the accelerator needed fixing. When started it is wide open. The previous owner told me it's been sitting for 5 or more yrs. I paid 1500. But I'm needing advice
/ Throttle stuck wide open #2
Welcome to TBN.
Can you tell whether it is the linkage or the pump?
Did you take the linkage off of the pump and see if the pump would return to idle?
If so, did you try to move the throttle shaft on the pum?
/ Throttle stuck wide open #3
Welcome to TBN.
Try lube spray the pivot points than work throttle level by hand with engine off.
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2020 Toro...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
SCAN TO RECEIVE TEXT UPDATES (A64276)
SCAN TO RECEIVE...
CASE TV380 SKID STEER (A64279)
CASE TV380 SKID...
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
