3-Point Hitch Three point hitch clearance on a 2520
   / Three point hitch clearance on a 2520 #31
Only downside would be no added stability on hills.:)
   / Three point hitch clearance on a 2520 #32
I left my tires/wheels in the wide position. I don't want spacers, because they only add more stress to the rear end. Its simply more leverage, so breakage is "possible".
   / Three point hitch clearance on a 2520 #33
I let you know if anything breaks.:) No worries.
   / Three point hitch clearance on a 2520 #34
The biggest theoretical downside of that setup as opposed to the typical iMatch setup is that you'd be more susceptible to lateral forces (sway) than with the wider stance for the arms. Whether that actually is an issue in practice for an implement that the 2520 would normally utilize is a completely different story - since iMatch is the same for all Cat1 tractors (including much larger ones) my gut says you shouldn't have an issue.
I've got a few feelers out for a source on 2520 spacers since it comes up every so often, but most of the fabricators around me deal mostly in sheet metal so finding stock steel that size is rough (and expensive!). I'll be sure to post if I can find anything.
   / Three point hitch clearance on a 2520 #35
I am sure someone will soon make them available. I may soon offer them myself if no one else does .I like the drawing Nate M has posted. If I were to manufacture them they would be 2" steel spacers as he posted.I beleive that is all you need. Hopefully he will post results.
   / Three point hitch clearance on a 2520 #36
Just remember if you mow in TIGHT spaces, you'll be 4 inches wider and that may keep you out of areas. It might also affect your footprint if you have a narrow bucket and attempt to dig with it!
   / Three point hitch clearance on a 2520 #37
Well, I finaly got around to installing the spacers I mentioned before.
I have attached some pics of the project.
I think it will work well for my needs. There is appoximately 3 inches of clearance between the 3ph arms and the tire tread.
The only thing I would do different is make the recess about an 1/8" deeper that fits over the boss on the hub. I had to shim behind the spacer to make up the difference. I would also make a boss on the spacer like Hillstone advised. This would help in getting the wheel back on.
I also had some additional weights made. 14" OD x 2" thick. I put two of these on each wheel. The weight of those plus the spacers should be just over 500 lbs.
Not sure if I like the look of the black wheel weights in the rims. I may paint them JD Yellow...
   / Three point hitch clearance on a 2520 #38
I agree 110%, paint the weights yellow!! Tractor looks funny from the rear, but if it works for your needs, good job!!
   / Three point hitch clearance on a 2520 #39
I definately looks silly being so wide in the rear, but I bet its stable as heck.
   / Three point hitch clearance on a 2520 #40
Hi Guys,
I am looking for a tractor for my dad to replace our Case 1120. The Deere 2520 is definitely in the running along with the Massey 1528 and Kubota 2630 & 3030. I have to say I find this to be an irritating problem with the 2520 along with Deere'e lack of a 3-speed hydro, a decent seat like the X-Series S/E and their Mickey Mouse 47" snowblower setup. I like this machine but why does Deere feel so compelled to cut corners on everything but the price? A blower that is too narrow for the tractor? Nod goes to Kubota and Massey and NH here as all have 60's avail. All others have loaders designed for that specific model tractor, good seating and no need to drill a hole in the fender for the ind. mower lift or add a diverter valve for the MMM. Do they have a rear remote outlet avail yet? My Case had that from the factory in 1994 along with a tilt wheel. At the end of the day, this is still a sweet tractor but why should we have to change seats, add wheel spacers and MMM front caster zerks and otherwise re-design a nice tractor? Not being a jerk here just hoping Deere is a frequent reader and hears some legitimate concerns. I will prob buy him this machine since an old supervisor at Hood works for a big Deere shop 10 minutes from his house.
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
Killbros 260 Seed Conveyor (A55302)
Killbros 260 Seed...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2014 Nissan Murano AWD SUV (A55758)
2014 Nissan Murano...
