Phil Timmons
Platinum Member
- Joined
- Mar 18, 2008
- Messages
- 637
On the solar panel and wind generator companies...what happens when the subsidies end or the companies themselves go out of business?
In the case of Solar PV -- the install prices / costs are now down so cheap -- it does not matter. Full install costs are down around $1 per Watt. That is WITHOUT any subsidies.
Real Thing now (2026) is that Low-Cost Solar PV has is a 50% Punitive Tariff AGAINST it. You follow? You may have thought the Feds were promoting it? Turns out Coal, Nukes, and Gas are all on Welfare AGAINST it.
That works out to 2 to 3 cents per kWh, across the Service Life of the Panels. Service Life is now estimated at 30 to 40 years. With little-to-no Operations and Maintenance Expense. And when it is due for replacement -- the racks, wiring, connections can all stay in place, so it only costs 1/5th or less to just swap out the panels for the NEXT 40 years.
So with that low of Wholesale Prices / Costs -- nothing can really match it. With these numbers, Solar may saturate the daytime grid, and force most everything else off. Which is not really a good thing, either. So this model has a very low-risk of business failure, as someone else (operator) will just snag any existing project up for the Cash Flow.
