This Old Barn
/ This Old Barn #11
WOW!. you must really love woodworking and have a good bank account to fix this, you also have a lot of courage to work on this in the condition it was in!.. why was the barn built like this instead of having the floors supported by a foundation, though?..
/ This Old Barn #12
That is quite some project you have there. Much much work & dedication required.
/ This Old Barn #13
If this was mine, I would add joist hangers under those beams to ensure that they did not split in the future.
Really nice barn!!!!
^^^^^^ ABSOLUTELY....YES!!!
/ This Old Barn
When I bought the barn the siding on two sides was failing, and I hired real carpenters to replace it. They discovered that the sill on one side had rotted out, and they jacked it up and replaced it. That was expensive enough that I decided that from now on whatever gets done has to be done by me! The work that I'm doing now isn't that expensive, just a few pieces of treated 2x8's. The biggest expense of this phase was the dumpster to take away the concrete that I broke up. But it's incredibly time-consuming. To the extent possible I'm trying to recreate the original wood work, which means that each piece of wood has to be shaped and fitted, sometimes I'll spend a couple of hours on a single piece. What I'm detailing here is the compression of about five years of intermittent work.
I have been very careful not to do anything that I considered dangerous. Once I got the loft supported from above it was all working down. Despite everything looking crazy, I knew it had some strength. When I bought it tractors were still being parked in it and several tons of hay was going into the loft each summer. When the carpenters replaced the sill they had jacked up the wall from the floor. I think about that now and I mutter "holy ***!" to myself.
I can only speculate. They seemed to value having the open basement. Accounts differ on whether animals were kept in the basement during the winter for warmth, or whether it was just used for storage and manure management. Also, they didn't have any treated lumber, and this is a very humid climate where wood rots quickly. Having fewer points where the framing touches the ground would make for a longer-lasting building.
/ This Old Barn
Thanks for sharing. Do you know what wood was used for the original post and beams?
I don't. It's some sort of pine, maybe hemlock. Most of the framing and sheathing is white pine but the beams seem to be more rot-resistant. It's old growth and the rings are incredibly close together.
/ This Old Barn #20
Fantastic project you have going there!
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
