Third cry for help
/ Third cry for help #21
From what I understand it is easier to get a uniformly level roadway faster with a MM blade. The washboarding caused by the front or rear of the tractor going over humps is reduced because you're not fiddling with the height adjustment of a front or rear blade to compensate.
Yep, that's the idea. A construction road grader works the same way. The John Deere I run has a 22' wheelbase with the blade just behind center. So if the front tires go over a 6" hump the blade only rises 3". Make two or three passes and the hump basically disappears.
/ Third cry for help #22
I understand the washboard effect and wonder if the wheelbase on a BX with a mid-mount blade is enough to make it more effective than a rear blade with guide wheels. After all when you add guide wheels to a blade or rake you are pretty much doing the same thing and it would seem to be a cheaper way to go. It would also seem to be an easier system to switch from when the tractor was needed for other tasks. With guide wheels I do not have to do any height adjustment while raking the drive, the guide wheels maintain a constant height like a mid-mount blade would.
MarkV
/ Third cry for help #23
MarkV
True that.
/ Third cry for help #24
Agreed. However, the true goal for me is maneuverability. Many of the projects I would like to do would not be possible with the added length of a rear blade. Guide wheels would make it worse.
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2010 Ford Crown Victoria (A61574)
2010 Ford Crown...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
4022CFL (A59228)
4022CFL (A59228)
