Theo
/ Theo #1
Theodorus
Thohoyandou
Landini
Hi!
I am from South Africa and have built a tow behind vibrating roller.
The drum is 1 metre high and 2 metres long
I have a eccentric weighted shaft running through the middle of the drum.
What I would like to know is at what speed must this eccentric weighted shaft turn and does it matter if it turns clockwise or anti clockwise
I intend using 2 cylinder Deutz engine to drive via fan belts and a PTO clutch
The whole unit weighs + 3 ton
All advice is appreciated.
/ Theo #2
Pictures would be extremely helpful. Is the Deutz engine mounted on the roller assembly?
/ Theo
Hi! Bob
The motor is mounted on the rear of the frame.
I have removed the motor at this stage as the belts kept on coming off etc. etc.
Due to the above mentioned belt problems I have decided to fit a PTO clutch.
I will take photo's and will try to post them but I am not to clued up when it comes to posting on forums, espeicially pictures.
Kind Regards.
Theo.
/ Theo #4
Above the reply box, select the fourth icon from the left (a little tree in a box) and follow instructions. It's really pretty easy if you already have the images on your computer.
I think it was a wise choice to remove the engine from the frame, unless it was extremely isolated. Which could account for having belt issues.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2019 Deere 35G (A64126)
2019 Deere 35G...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2022 EZ-GO ELITE...
3097 (A63117)
3097 (A63117)
