The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
I have a brand new (25 hours) WR Long 3rd-function valve (operates my EA grapple) that is leaking/FLOWING from the A-port/top allen-hex fitting... Does anyone know why/had this experience...View attachment 534499View attachment 534500
Nelson Long says those haven't been a problem. The plug, which ironically says "zero-leak gold", has two forms of leak protection. It has a tapered head and an o ring.
Have you tried to tighten the plug?
If not, try that first.
If you have, Nelson said they can send a new plug(s) out as a remedy, but you'll need to go through the dealer who ordered it from WR Long(don't think it was us).
I hope this helps.
Keep us posted.
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,072
I hope this helps.
Keep us posted.
Travis[/QUOTE
Thanks for 'being there' Travis... I have a LOT of work scheduled/pre-paid for this machine/YOUR EA grapple and so far it has been performing NOT ONLY FLAWLESSLY BUT F'ING IMPRESSIVE/AWESOME... I have made NO/ZERO adjustments for fear that I might be changing a psi setting... I am unfamiliar with these particular electric-over-hydraulic-valves but I am NOT a stranger to hydraulics (on large/commercial fishing vessels and associated winch/steering/boom-lift OEM Design/Engineering)... I wanted to leave all settings/ports/plugs as they were for forensic diagnosis... I have contacted my MOST appreciated dealer and they are 'on-it' also... Tractor-Dealer/EA/WR Long/Et al are all responding FANTASTIC... Thanks for the help/support... OK, first thing I will do is try to tighten the leaking 'allen-hex-plug' since I now know it is not a psi setting/adjustment... FYI, I have gone over/reviewed EVERYTHING and see NOTHING amiss and can't recall any incident that would have caused an extreme over-psi or flow-interruption unless there is something in the hydraulic fluid (IE Teflon tape) which is highly unlikely due to the volume/filtration/age...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,073
Can't let a lid polemic pass without jumpin' in. My ranch hand pointed out that when he chomps down on a load of Yaupon with the single lid on our 72" Wicked, the Yaupon itself tightly squeezes the whole wad together securely.
Here he is transporting a batch a quarter of a mile without losing any. The red sunshade of the tractor is barely visible above the massive bundle and a splash of daylight can be glimpsed below.
5D6NmeczkO0vEl-gjwMeLEPQIDm9iKFhOwumsFO5rQysJ2lExWWz_MVD04abQhwVfZMvGSZZqmsVY2LQ43ofpxKf6DdOrhk85N3h6N6YMXE03hODQ4iA7Ni9uT-A3NLb-HjSNtTqER_x41wTxcIdJdDYtbqjOOE0d2fH-zVu99InXeeopajmEoD80o2je4HJUTM8pGTM6TVq5iVA5Q5w35_A38GhoLr_S6Vu9uSNzBXCSxtplb759_8iWGwYjKABpNYeAwMCPm0iVnJEytneNKvKxOardO3_Rso8dYWzpJqk-JNvkdmaKsREKWTWDfs6U_Y6jfv94U6vbzCgREGfG6sZUf4yLUif86KDCyE1SqrqA4sOIOXv4AO7JtCvRgI0330fisQVNntSZFSp7gD5MYqDwK0skzVDlFt5lBjWXk0iNp1zhWxQ_QHWLZwj1x_hCLGsFxmYXEwwgqgxDVvA-kZoqB0i9Bnyq5WuSFov3Eavs2g76il89T57yFH1c_8XjaOP3_-2gliyx1K4hhKtnKEwFMyh2Le-6cRpKNUFg4SYEq-U5ZnCIighvcS3kUK4NfHCPfGMp8_CeEKQnnucs3gjtmPKr4et6LYy5BjU=w877-h654-no
Aww, Mad Mac, you're just toying with us. I don't think there's really a tractor in there. ;)
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,074
I hope this helps.
Keep us posted.
Travis
I hope this helps.
Keep us posted.
Travis[/QUOTE
I tightened those A-port allen-hex-plugs and a A-port-fitting on top of the valve and it solved the problem... The allen-hex-plug was so loose it could have fallen out... Not sure why... Apparently it has been weeping/leaking but I did not notice, which is unusual because I take meticulous care of my equipment... I was initially afraid to tighten them because I thought they might be pilot-operated/psi adjustments... Anyway, after tightening things I ran the tractor/grapple-bucket all day with no issues... Man I love this rig... Thanks again Travis for YOUR prompt/informative reply/help... MUCH appreciated...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,075
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,076
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,078
That’s awesome
Hello.... Just posted my Wicked Tractor Grapple movie trailer on my youtube page! I'm going to be featuring the grapple in some of my videos in the next few months. Thought you might enjoy a scare! Have a great day!
Everyone should watch this video:
I've never seen anything like it. Simply AWESOME, man!!! :cool2: :drink: :dance1: :shocked:
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,080
why can't I see this. When I click on the link, it comes up ''about blank in the search bar''. Nothing else
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
2013 Ram 1500 Crew Cab Pickup Truck (A55852)
2013 Ram 1500 Crew...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
2013 Ford F450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F450 4x4...
