The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,021
Maybe you could cut off the outside tines, remove most of the pipe and reweld the outside tines back. That would get you down to 62" or so. I think the structural issue would depend on whether the outside tines are different than the inner tines. I've not seen an EA close up but I've seen some grapples where the outside tines were thicker.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,022
The outer tines have no holes in the bottom of the L, the inner ones do. The way the tip of the inner tines are designed with the bend going up to the pipe, which would prevent it from being flush like the original outer tine as well.
Bingo. It wouldn't be as easy as it may look from a distance. :thumbsup:
Travis
Here's a new review from Stephen. He has our 60" Single Lid Wicked Grapple on his Kioti DK45 with a KL451 loader.
"Simple. The best attachment I've ever bought. Having nine acres in southern Oregon with a ton of down trees and limbs it was nice to simply pick up large piles of limbs and drive them over to the burn pile. Quick attach just click, attach the hydraulic line and start using it. Boy does it save the time and work."
I was extremely pleased will all of the Wicked Grapple talk and other activity in the EA Channel Facebook Group over the weekend. COME JOIN US!
Several pics and a couple of videos were posted by proud owners, including this 60" Single Lid Wicked Grapple on a John Deere 3046R.
This guy from Michigan did an excellent job of clearing and grading a food plot with his new Wicked Grapple and EA 30-70 Box Blade.
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,026
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,029
Sharing this for no other reason than, well, I really liked the picture....and you can kind of see the grapple. LOL
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,031
You deserve a beer and a back rub after loading those rocks/concrete. Been there and done that. One of my least favorite jobs.
That man has worked for my late father and now for me for more than 40 years.
I did move a few rocks and most definitely drank some beer.
When my two dogs are barking to be fed or let outside, I tell them, "Just a minute."
I was so tired after my shower, I was telling myself, "Just a minute."
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,034
Hi All,
I too am starting to do research on a grapple for my nx5010. Based on this really looong thread I was thinking about the 54" Wicked single lid grapple. That said, I do have three questions that I didn't see or have overlooked.
1) Based on the size of my tractor will I have any issues with being able to see the outside edge of the grapple easily for alignment? I think I read yes on one of the threads for this question but wanted to confirm.
2) Based on the size of my tractor will I have any issues with seeing the single lid to understand when I have the load fully secured or do you guys just rely on the sound of the hydraulics to know you're there?
3) Don't know from an engineering perspective if this would be viable but are there any plans in the works to put cutting or digging tines on the back side of this grapple so it could be used for backdragging roots? (wishful thinking but doesn't hurt to ask:))
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,035
Hi Bigfish50. Great grapple choice and IMO a perfect match for your NX.
1) I can tell you that my Kioti DK40se is almost exactly the same size as yours and has the identical loader. I can easily see the outside edge if I need to come very close to something just by leaning to that side. My grapple is a 48" and I wouldn't worry about the 54".
2) No issue seeing if the load is secure. For starters you will learn what fully closed looks like but more importantly you will feel the lid clamp on the load and see the load compress. Remember this is an L shaped grapple so gravity is doing 90% of the work in securing the load. The lid mostly just pins the load and keeps things from bouncing around or rolling out the front. If you REALLY want to make sure you can curl the grapple after closing and see the tips of the lid. I never bother and have never had any issue securing the load.
3) Interesting thought but unless you engineer something hydraulic to retract the digging tines on the back of the grapple ($$$ and weight) you would find yourself inadvertently ripping things you didn't intend to when you go to grapple an object or pile of brush. I understand the desire and would suggest you research a Ratchet Rake attachment for your standard bucket which will do pretty much what you are talking about for shallow (3") roots. To get at deeper roots you'd probably be better off with a 3PT subsoiler type implement or just use the grapple going forwards.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,036
Thanks IT. All that makes sense. Regarding point 3 I was looking at some of the root rake grapples and it seems some of those have that ability to backdrag so I thought that might be something useful to have on a regular grapple as well. Oh well as I said wishful thinking. I'll prolly reach out to the folks at EA in the next few days to see if I can't get something in the works.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,037
The clamshell or root rake grapples do have near vertical bottom tines that could be used to back drag but I don't know how efficient it would be as the tines still point forwards so would tend to push roots down and drag over them rather than ripping. Also, SSQA is designed mostly for pushing and lifting. You can certainly back drag but you're putting a lot of stress on the pins and that's not really what they are designed for. Back dragging with a bucket is unlikely to generate the shock loads that back dragging with a submerged tine would deliver when it hits a big rock or even just a solid root. There are better tools for that sort of deep root ripping.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,038
