The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,621
X3 buckeye! We've survived it for over 4 years since I started this thread; back when the very first Wicked Grapple was on the welding table!!
Travis
And EA builds better grapples because of it !! Tested by fire. :D
That's right, Tom. Proven by EricTheOracle, the #1 roughest attachment tester in the land...well, right next to Ted. :laughing:
Travis
Thanks to Snowback for this BEAUTIFUL pic!!
His 2538 Mahindra with precious cargo!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,624
Just talked to Travis what I nice fellow.
I want to do a grapple and a true third function on my Mahindra 3016. I was hoping they had destructions on hand that I could read to make sure I understood how it was installed. Alas they don't. The inter web is useless as well.
Don't worry Travis once I get it understood I will be ordering both items from you.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,625
My pleasure! Happy Inauguration day to all!
Travis - do you think these links below could be helpful for Laderbuilt?
EA is part of an impressive dealer list for WR Long.
Valve Kits
http://www.wrlonginc.com/Hyd DO3B Flow Diagram.pdf
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,626
Valve Kits
Thanks that is a useful link that offers some info. I'm more after a detail step on HOW to install the valve such as mounting location, hose routing, etc. I like to read and re read the info till I know it backwards and forwards. That way I fully understand what's involved and pre plan any deviations I might want to do prior to starting.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,627
Maybe there is someone with a Mahindra 3016 that can help you out with pictures? I do know that the WR Long kits that EA sells are basically custom made to bolt right on for each machine. Even the hose lengths are pre-cut and EA makes sure your connections all mate up with the grapple too. All you need to do is work over the handle to get the switch grip installed and then find a hot lead for power to the switch and back to the actuator. Then bolt up, wire up, and route hoses down your loader arm. It is probably a couple hours worth of work, and I had my dealer do it, so please don't hear me saying it is super easy, but I think a mechanically inclined person can probably knock it out. Here is a snapshot of how one bolts up to a 2538. You can see the bracket and such. I've heard some folks say getting the original handle/grip off is one of the more difficult tasks... Good luck!
Sounds good. Hopefully more Mahindra owners on TBN can help you out!
Travis
This Wicked Grapple and 3rd Function kit review came in over the weekend from Bart in Florida. He has our Wicked Grapple on his John Deere 4052M.
WR Long 3rd Function Valve Kit
"Easy Peazy"
"I literally installed this kit on my 2016 JD 4052M in about 45 mins. I cant believe AgPro wanted $500-600 to install. The product was perfect."
60" Dual Lid Wicked Grapple
"My Incredible Grapple"
"What else can you say but "wow", I knew they'd be nice but i had no idea they were as tough as the really are at their weight. I have the 60 inch dual lid and i love it. Also. Be careful. The grapple tines are razor sharp when you receive it! Perfect laser cutting as the lids jaws literally could pick up a human hair as the shut almost seamlessly with the grapple. I have used the grapple and it is tough as nails and the serrated tines cut easily thru hard pack, rocky soil and pretty much anything. I HAVE YET TO DROP A LOG! A+ on an amazing grapple."
He's the guy that shared this awesome pic around a week ago.
Travis
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
UNUSED SDLANCH SDLC2030FT20'X30' ALL STEEL CARPORT (A57193)
UNUSED SDLANCH...
Year: 2017 Make: Mitsubishi Model: Outlander Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A56859)
Year: 2017 Make...
2014 Walker Compactor (A55787)
2014 Walker...
2017 CATERPILLAR 279D SKID STEER (A52707)
2017 CATERPILLAR...
