The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
Well I done did order it. Did it online. Travis soon called me to nail down my hose/connector requirements. I think this is my fourth attachment from EA. They are a class act over there.
If I just can't handle the outer tines without loosing sleep, I can always modificate it. But I'm sure it will be fine. Often, my laziness wins out over my ideas.
IslandTractor, thanks for the offer. It has been your logical opinions about grapple width that pushed me in the narrower direction.
Thanks xtn!!
FYI, the design of our new 52" Wicked Utility Grapple makes uniform tine spacing possible, however it will weigh at least 200 pounds more. I am confident that you made the right choice!!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #732
Travis you just did what i was wanting to do on my new wicket grapple that was to add a Piranha tooth bar to cut out sticker bushes to pile up and burn. trying to just grapple then you always hit roots Would be easy for you to cut to fit your Grapples as a add on
Yea, the horizontal gussets on the new Wicked Utility Grapple make it easy to add/remove the shearing plates. It's definitely a cool, unique addition that should add more versatility......oh, and it's Wicked!!
The laminated vertical gussets on the Compact Wicked Grapple make it easier for compact tractors to push the tines through the soil.
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #734
If you mount a Piranha bar on a Wicked grapple, you're getting mighty close to a machine that belongs in one of the Mad Max movies!
Especially with a custom paint job!! :thumbsup:
   / The WICKED Root & Debris GRAPPLE!!!!!!! #736
I suggest not putting ribs on the leading tine side supports attached to the lower, horizontal round bar. The reason is that bush would tend to hang up on those teeth on release, and the teeth are not in a good place to "saw" material anyway.
Just a passing thought, so take it for what its worth.
We have several Wicked Grapples in stock and waiting for a new home!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #738
   / The WICKED Root & Debris GRAPPLE!!!!!!! #739
Someone needs to step up and buy ALL of those.....
   / The WICKED Root & Debris GRAPPLE!!!!!!! #740
I did my part to keep American workers employed, just got delivered this week.
This is my 5th attachment from EA, to me this is the perfect model for American manufacturing, direct from the manufacturer to the customer. Excellent customer service and quality.
2013 PETERBILT 386 (A58214)
2013 PETERBILT 386...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
JOHN DEERE 9570 RX (A58214)
JOHN DEERE 9570 RX...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
2021 Caterpillar XQ125 125kVA Towable Diesel Generator (A55973)
2021 Caterpillar...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
