The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #721
FWIW, I would go with the lighter grapple with the CK and heavier with a DK or NX. Unless brush is the only thing you intend to grapple, it's best to maximize net lift capacity for the bigger rocks, stumps and logs you're going to deal with.
For what it's worth, if I had a ck 35 I would definitely go with the smaller lighter grapple. It is what I have on my DK35se and my lift capacity is several hundred lbs more than the CK.
That's pretty much the way I'm leaning too & for the same reasons.
Thank you both for the insight & info.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #722
Well I done did order it. Did it online. Travis soon called me to nail down my hose/connector requirements. I think this is my fourth attachment from EA. They are a class act over there.
If I just can't handle the outer tines without loosing sleep, I can always modificate it. But I'm sure it will be fine. Often, my laziness wins out over my ideas.
IslandTractor, thanks for the offer. It has been your logical opinions about grapple width that pushed me in the narrower direction.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #723
Well I done did order it. Did it online. Travis soon called me to nail down my hose/connector requirements. I think this is my fourth attachment from EA. They are a class act over there. If I just can't handle the outer tines without loosing sleep, I can always modificate it. But I'm sure it will be fine. Often, my laziness wins out over my ideas. IslandTractor, thanks for the offer. It has been your logical opinions about grapple width that pushed me in the narrower direction.
You'll be happy with your grapple. Everybody loves whatever grapple they have and,of course, any grapple mounted on your tractor is better than delaying and worrying about details that really don't amount to much in practice.
OH NO!! :eek:
I was ready to share some teaser pics of the new Wicked Utility Grapple from the drawing board.......but........unable to upload pics!!! :smiley_aafz:
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #725
I used to keep the bucket on my FEL while brushhogging ... Today was the first time I used the grapple while brushhogging jobs. What a great addition. Being able to move small brush or down trees that contractors have scattered about is really a time saver.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #726
Great for popping out rocks or small stumps so you don't hit them again next time too.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #727
Bingo! My Bush Hog 3008 and 84" grapple have not been off our NH TL100A I over a year.
If I run across a big limb, from dead tree, or a downed dead tree I can use grapple to clean up and then continue mowing.
Sent from my iPad using TractorByNet
   / The WICKED Root & Debris GRAPPLE!!!!!!! #728
The grapple and whatever is attached is my "standard config" In fact, it has been awhile since I was in bucket mode, but that is coming with piling material on an existing septic system that is only 18" into the ground at the house I'm wintering at this year.
Nice view Eric!
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
2019 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2019 FREIGHTLINER...
