The Ultimate Toolbox!
/ The Ultimate Toolbox! #11
Is one half of the box refrigerated to hold beer????/QUOTE]
If the Operator is considered an attachment that would be a worthwhile addition. :D:D:D
Toolboxes are nice for holding an almost inexhaustible assortment of goodies required to maintain the operator and machine in the field!:D
The sleekly styled newer tractors leave little room for this addition.:(
/ The Ultimate Toolbox! #12
My toolbox is behind my seat, and between my ROPS. It's very handy there for attaching implements.
Eddie
tallyho8,
That's exactly how I would describe this toolbox idea by KubotaTerry! http://www.tractorbynet.com/forums/kubota-owning-operating/87050-toolbox-l3400-la463.html Can't wait to see what you've come up with. Hopefully it's just a little bigger!
Thank you for ruining my day. I guess I have not made the great discovery after all. :( I thought I was the first one to think of using the available space in the fel but I see that KubotaTerry thought of it a couple of years before I did. I didn't have a Kubota back in 2006 when he wrote that thread so I didn't read the Kubota forum back then. I also found someone that designed a toolbox almost like mine so this is not my discovery either.
What is still unique about mine is that I put this toolbox in this place. And even though KubotaTerry's idea is great, what sets mine apart is that you can remove the toolbox and carry all the tools with you wherever you need to go. So I will go ahead and show you what I have in case anyone is interested and has a fel like mine. You can make 2 toolboxes for your tractor, one on each side.
It goes in the hole in the fel as seen in photo 1.
It only takes a piece of 3" pvc pipe and 3 fittings as you see in photo 2.
You cut the pipe to the correct length to fit all the way in the hole without rubbing on the tubing at the rear of the right side hole. The left side is one inch longer than the right side on mine. Then I fit mine in a fraction further than flush so nothing can hit it as seen in photo 3.
The toolbox can be removed to carry with you to the job area. To keep the lid screwed tight so tools don't fall out I use this wrench which I keep in the stock toolbox that came with the Kubota. Photos 4 and 5.
This shows the amount of tools that fit in one toolbox. This is not the typical tools that I carry around. I also lined the inside with a thin piece of foam that I had to prevent rattling. Photo 6.
I have not attached the toolboxes yet. I have thought of a couple of ways to attach them where I can remove one easily to carry it around. Maybe some of you could suggest a better way to attach them where they can be easily removed. If not, I will post how I did it in a few days. Also, you may want to paint it orange. :)
/ The Ultimate Toolbox! #14
Cut the tubes so they will slide in the loader tube far enough to use the plugs like KubotaTerry used to seal it up.
Terry
/ The Ultimate Toolbox! #17
tallyho8, Sorry if I ruined your day but I think your idea is as innovative as KubotaTerry's and much more versatile.
Imagine, you could have several boxes stocked with specific tools or hardware for different tasks/implements. Then just switch them out at the shed or barn or garage... If you solvent weld, you could whip up a custom thermos or at least a nice little cooler. I'm imagining a nice little tap on the side of the machine... maybe that would be better for the front loader tube. You could easily bring your tools in at night if you need to leave your tractor around those with sticky fingers. I think the possibilities are pretty broad.
If you mount a magnet at the end, I bet it will stay put without making it too complicated.
I like it. I'm going to make one but I might go for the black ABS plastic and a brass plug.
/ The Ultimate Toolbox! #18
Eddie
I subscribe to to medical mantra - "Do no harm." I try to add no weight above the CM of the tractor. Im going to put mine on the axle housing inside the rear wheels. Theres plenty of room for this on the 7520.:)
larry
/ The Ultimate Toolbox! #19
Kubota already sells the ultimate toolbox- they named it the RTV !
/ The Ultimate Toolbox! #20
some good idears in here...
now if i only had a larger diameter hole in my FEL supports........where's my torch?:eek:
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2018 International DuraStar 4300 2,000 Gallon Water Truck (A59230)
2018 International...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
