The "right sized" tractor for our land?
   / The "right sized" tractor for our land? #1
IHDiesel73L
We have about 2 acres tucked back among 250 acres of farmland and woods which surrounds us. About half of our land is cleared with the house, deck/patio, barn and small toolshed. Behind that is the "yard" which I mow with a zero turn. Then there are a few old animal pens (previous owner had sheep-we may get goats in the future), behind that is a small field that slopes down to our pond, then there is about 3/4 of an acre of swampy woods behind that. My neighbor on the south side has an old Kubota L245DT with FEL that he lets me use basically whenever I need it to do various things around the property, but I'd really like to have my own at this point. The 245DT seems to be sized pretty well for the trails that we have and the uneven terrain. What is a 245DT considered? Compact? Sub-compact? According to Tractordata it is 25HP. I've used it to skid logs, pull snags down, pop stumps out, etc...and the limiting factor has always been traction. I've started spinning wheels before I've ever had the tractor bog down-there is no weight on it at all and I would be interested to see what it could do with filled tires, wheel weights or a front/rear weight box. That said it does pretty much what I need it to do. Around here I don't really have a need to pull implements like a brush hog-about the only thing it would pull would be a trailer of some sort. Rather than having a tractor for a few dedicated tasks, I will use the tractor mostly for doing "odd jobs" associated with fixing up/reclaiming our old farm property.
Recurring tasks:
  • Moving logs/firewood.
  • Gravel road maintenance (filling potholes, pulling a drag, etc...).
  • Snow cleanup (not road plowing-I handle that with the truck) around the house and buildings.
Upcoming projects that I'll use the tractor for:
  • Moving gravel/grading 25' x 60' parking area in prepartion for paving.
  • Building a boulder wall (using rock sourced from the property) alongside the parking area.
  • Spreading gravel over a corduroy road I'm building through the swamp in the rear of the property.
  • Tearing down an old 16' x 20' timber frame barn and building a new 20' x 32' pole barn.
  • Hauling boulders and other material down to our pond to build up the bank.
Given all of this, should I stick with something comparable to the L245DT, go a bit smaller for greater maneuverability (I definitely don't need something larger)? I am confident in saying that I absolutely need 4WD. Too much mud and uneven ground around here. My neighbor bought his property in 1975 and started with a 2WD tractor that got stuck pretty much anywhere he took it. After about two years of that he bought the Kubota and never got stuck again.
   / The "right sized" tractor for our land? #2
Recurring tasks:
Kinda answered your own question there, eh? :)
Not exactly? I mean, as I said, the L245DT is great, but its also 40+ years old. First, being somewhat new to this I honestly don't know the difference between a CUT and a SCUT in terms of size, horsepower, etc...in order to narrow down what I'm looking at. What is the L245DT considered? Compact or Subcompact? Would I be able to get a comparable level of power in a smaller, newer tractor, etc...? Those are the questions I'm trying to answer.
   / The "right sized" tractor for our land? #5
Put some weight on the 3pt of the L245. The EASIEST way to me is to put a 3pt pallet fork attachment such as Pallet Forks, Pallet Fork, 3 Point Pallet Forks 3 Pt Pallet | Agri Supply 72511 on the L245 and mount a barrel of sand or two on it.
You can always use the pallet fork attachment later if you buy a tractor.
It's a little confusing about how much land you own and how much you want to spend on a tractor. But I'm thinking you own 2 acres and don't want to spend much. Since a new tractor will probably run $15K plus and even a good used one $5K plus I'd focus on keeping your generous neighbor happy and enhancing his tools. Maybe buy a boxblade.
IF you've got 250 acres of woodland you need a 50HP tractor.
We only own the two acres but its not as if we're in the middle of a subdivision. We are sandwiched between a working hay farm (120 acres) on the north side and my neighbor's place (old overgrown farm and woodlot-about 130 acres) on the south side. We're over a quarter of a mile off of the county road along a gravel lane that we share with my neighbor. The lane belongs to him and we only have easement over it to access our house, but I help him with road maintenance, share in the cost of stone, etc... He also allows me to cut firewood from blowdowns on his land, dump brush on it and pick boulders off of it for building things around my place. As far as how much I'd like to spend? I'd LOVE to purchase a tractor comparable to the L245 with FEL/4x4 for $5K, but the market around here (Northwestern NJ/Lehigh Valley area) runs a bit higher than that. I check Craigslist, Facebook, etc...a lot and have never seen such a tractor for less than $9K. Likewise, I'm not keen on the idea of financing a $15K tractor either.
A good idea, but I would just feel better owning my own machine-as it is I'm always paranoid about pushing his tractor a little too hard and possibly breaking something.
   / The "right sized" tractor for our land? #7
That's one thing about these little compact Kubotas.... they seem to hold their resale value very well. Sometimes it's hard to find them for much less $$ than new.
   / The "right sized" tractor for our land? #8
I sold my rather tired L275 (one step up from the 245) 3 years ago for $2700... I doubt that you will find one in decent shape for the amount you would like to spend. I know that I looked for several years trying to find one in better condition than what I had, and as you said they want 8-10K... and don't seem to last long at that price.
The Kioti CK2610 is very similar in size and HP to my old 275, but I don't think you will find one of those in your price range, either.
   / The "right sized" tractor for our land? #9
Kubota L245
1976 - 1985 L Series
Compact Utility tractor
Manufacturer: Kubota
Factory: Japan
Original price (USD)
$4,000 (1977 )
Variants:
L245DT: 4WD
L245HC: high clearance
Kubota L245 Engine:
Kubota DH1101
diesel
3-cylinder
liquid-cooled
68.3 ci [1.1 L]
Bore/Stroke: 3.00x3.23 inches [76 x 82 mm]
Power: 25 hp [18.6 kW]
Air cleaner: paper element
Compression: 21:1
Rated RPM: 2800
Starter volts: 12
Oil capacity: 5.2 qts [4.9 L]
Coolant capacity: 7 qts [6.6 L]
Kubota L245 Power:
Engine: 25 hp [18.6 kW]
Drawbar (claimed): 17.8 hp [13.3 kW]
PTO (claimed): 22 hp [16.4 kW]
Drawbar (tested): 18.10 hp [13.5 kW]
PTO (tested): 22.35 hp [16.7 kW]
Capacity:
Fuel: 6 gal [22.7 L]
Hydraulic system: 8.7 gal [32.9 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 1540 lbs [698 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540/700/1000
Dimensions
4WD Weight (shipping): 2000 lbs [907 kg]
4WD Weight (operating): 2382 lbs [1080 kg]
Weight (ballasted): 3792 lbs [1720 kg]
Wheelbase: 63 inches [160 cm] (2WD)
61.2 inches [155 cm] (4WD)
Length: 101.5 inches [257 cm]
Width: 51.6 inches [131 cm]
Height (exhaust): 84.6 inches [214 cm] (L245HC)
4WD Ground clearance: 12 inches [30 cm]
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: manual
Brakes: differential mechanical wet disc
Cab: Open operator station. Two-post ROPS optional.
Hydraulics:
Type: open center
Capacity: 8.7 gal [32.9 L]
Pressure: 2000 psi [137.9 bar]
Total flow: 3.7 gpm [14.0 lpm]
Page information:
Last update: July 9, 2019
Copyright: Copyright 2019 TractorData LLC
Contact: Peter@TractorData.com
   / The "right sized" tractor for our land? #10
Slightly lighter (1,830 pounds) current Kubota model is LX2610.
Slightly heavier (2,600 pounds) current model is L2501.
VIDEO: Comparing Kubota's 26hp Compact Tractors - YouTube
Older near equivalent Kubota models:
B2320/B2620 (1,477 pounds)
B2650 (1,786 pounds)
L2800/L3400 (2,600 pounds)
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor weight is more important identifying compact tractor capability than tractor horsepower.
Bare tractor weight is a fundamental tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used. Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range.
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel ballast fourth.
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
1997 Ford F-450 Flatbed Truck, VIN # 1FDLF47F6VEB26852 (A57453)
1997 Ford F-450...
New/Unused Excavator Brush Flail Mower (A57454)
New/Unused...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
