The loose nut
/ The loose nut #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
My L3400 is only 10 months old. A few months ago while working in the woods I managed to get a flat in the rear tire. At the time I assumed I had come along side a rock & popped the bead.
Fast forward to yesterday. The machine has been sitting in the garage for almost a month. I start backing it out when I (literally) get that sinking feeling. Same tire is flat. So I look around and discover that the right turnbuckle on the 3 ph has loosened and the BX42 apparently has been rubbing on the inside of the (now) flat tire.
So I asume the chipper must have come around and given the tire a big enough whack to break the bead.
Again I am unable to get the bead seated so I call my friendly commercial tire dealer. After he fills it he says lets just check everything and gets his 'soapy water' jug. He quickly discovers the stem nut is not very tight and we can see air bubbling from the gasket. A check of the other 3 wheels showed 2 of them were low in air pressure and their nuts were also not fully tight.
I guess the lesson here is always check your nuts.
/ The loose nut #2
I had a similar problem, the valve was loose inside the stem allowing pressure to escape.
/ The loose nut #4
I have snug rear loaded tire couple times last year an half..figure it was do to working also cold/warm air temps over time.
/ The loose nut #5
I saw the subject for this thread "The loose nut" and thought you were referring to me.
/ The loose nut #7
to seat the bead use a flammable spray like starting fluid or carb cleaner and spray in and around the bead and in the tire and then light and it will burn then WOOOOF and seat the bead and put a pound or two of air in it. Have water to put and flame out that did not blow out.
I did this several weeks ago to seat some lawnmower tires that were of the bead and would not seat even with pressure on them.
OK now the safty police can tell me how unsafe this is. Bottom line is many farmer, loggers etc do this all the time, just be concious of what your doing, and please be smart and dont use something as flamible as gas.
/ The loose nut #8
that makes me really appreciate the aggravation a tubed tire sometimes gives you ( patching a flat.. etc.. )
soundguy
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
8ft Fork Extensions (A64553)
8ft Fork...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
