The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #41
Quite a few likes and responses for spam-vertising. Check this guy has two posts basically the same. Smh
Not spam-vertising, he is an Advertiser like many others on the forum: Advertise on TractorByNet – TractorByNet – Tractor Community & Resource
And his thread: The Original Tractor Relief Tool - Easier Hydraulic Connections
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #42
That's not the OP. Check the original post. It comes across like some random poster, not the advertiser, but is clearly fake. I've got no problem with an advertiser identified as such hawking their products to us.
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #43
I guessed wrong. You didn't specify which post.
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #44
Maybe instead of a push-in style, a quarter turn spiral acceptor might work better so instead of pushing you are turning. Like big truck air lines.
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #45
$125 bucks for that tool set actually isn't that crazy after you consider buying the parts and the drill and tap part.
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #46
You're right. If you have to buy all the parts, and then put in the time to fab, then just buying the tool isn't so bad.
I think I already had everything but the NPT plug, so mine probably cost me all of $4, plus spare parts already in the bin.
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #47
I've posted it before, but this is the clamp I made for this,
   / The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #48
5” c-clamp for me. Cheap.
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
