WinterDeere
Elite Member
This is correct. There is nearly zero stored energy in an incompressible fluid, like hydraulic fluid. You can build 1000 PSI or more, and still have very little stored energy.I don't think they'd have enough force to smack apart and whack me in the head.
It's compressible fluids, such as air, that store a lot of energy when compressed to high PSI. A 100 PSI air line rupture is far more exciting than a 3000 psi hydraulic line rupture, for this very reason. The larger the volume of compressed fluid, the more stored energy, and the more exciting the release. Think of those stories of failed air compressor reservoirs launching through shop walls, exploding tires, etc.
Yes, if you have a cylinder that can move to change the system volume, such as a hydraulic top link, this will usually prevent hydraulic lock-up. The two places where I need to use this tool are both cases where there is no cylinder or motor that can relieve the pressure:I know that the fluid within the implement and lines would still expand, even when lines form a closed loop, but for me, it has never prevented me from snapping them on the tractor fittings. I think the expanding fluid may be moving the hydraulic cylinder piston enough to not be overwhelming when connecting.
1. There is a set of long (16 feet?) lines that run from the rear of my tractor to the wrist on the loader. These are made to carry the 3rd channel hydraulics, which are hard-plumbed to behind the seat, out to the end of the loader, for use with a grapple, plow, anything where you need 3rd function on the end of the loader. The lines both have male on the inlet end, and are dead-ended in smaller m/f fittings out on the end of the loader. If the temperature rises a good bit since the time I last used them, it will be nearly impossible to plug them back into the tractor for their next use, without using either this tool or the trick of slamming the male fitting nipple against something to relieve the pressure.
2. My snow plow has opposing cylinders, with a set of lines that terminate male/female. I keep them plugged together, which helps to some degree, but still doesn't always prevent lock-up if the temperature rises 80F from last use.
