The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #41
Quite a few likes and responses for spam-vertising. Check this guy has two posts basically the same. Smh
Not spam-vertising, he is an Advertiser like many others on the forum: Advertise on TractorByNet – TractorByNet – Tractor Community & Resource
And his thread: The Original Tractor Relief Tool - Easier Hydraulic Connections
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #42
That's not the OP. Check the original post. It comes across like some random poster, not the advertiser, but is clearly fake. I've got no problem with an advertiser identified as such hawking their products to us.
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #43
I guessed wrong. You didn't specify which post.
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #44
Maybe instead of a push-in style, a quarter turn spiral acceptor might work better so instead of pushing you are turning. Like big truck air lines.
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #45
$125 bucks for that tool set actually isn't that crazy after you consider buying the parts and the drill and tap part.
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #46
You're right. If you have to buy all the parts, and then put in the time to fab, then just buying the tool isn't so bad.
I think I already had everything but the NPT plug, so mine probably cost me all of $4, plus spare parts already in the bin.
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #47
I've posted it before, but this is the clamp I made for this,
/ The Hydraulic Fight is Over - Hydraulic Coupling Pressure Relief Tool #48
5” c-clamp for me. Cheap.
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2004 Peterbilt 357 Tri-Axle Dump Truck (A59230)
2004 Peterbilt 357...
UNUSED FUTURE 3T HYD TILT BUCKET (A60432)
UNUSED FUTURE 3T...
Ingersoll Rand 175 S/A Towable Air Compressor (A59228)
Ingersoll Rand 175...
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
