the golden rules ?
/ the golden rules ? #41
The golden rules for TBN is never post about oil, hydro vs gear and the dreaded "I Drilled My ROPS". I was going to start a thread on these three subjects but chickened out. Thanks for letting me bring them up!
When I got my Kubota L3430 I drove around the yard several times, got pictures (smartest thing I did then) and tried out the backhoe. I then went across the field to a rock pile and moved a few rocks. The wet spot I drove across on the way out became bottomless going back in and I got stuck. Was able to get out with the FEL, but it sure wasn't clean anymore!
ksmmoto
/ the golden rules ? #42
Getting stuck may be a good thing. Do you want a wench? Think how easy it is to explain you need one, only a hundred or so, to save thousands of dollars worth of tractor. When you want to use your tractor, explain it has to get done now or it will be too muddy later, or you may need more tools to get it out. If she has a job for you that you don't want to do, explain you can do it but will probably get stuck and need more tools. You may be able to justify a 4x4 truck if you don't have one to pull the tractor out? Be inventive. I have been married 42 years, same wife, lots of different tools.
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
ALLEN AR16 BUGGY (A63569)
ALLEN AR16 BUGGY...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
