The gate
/ The gate
It'll be higher. Customer has picked up a Bluebird or equivalent and wants to use the driveway instead of the construction entrance.
/ The gate #202
i know myself i always like the idea of making everything 14 ft clearence, entrances,wires, doorways if possible, just cause that means anything that can be on the road will fit, of course if a truck pulls up and they have half the towns telephone wires trailing behind them, the yes 14 ft isnt enough, but if the drivers that incompetent then thats the least of the worries! how tall is the gate now anyhow?
/ The gate #203
<font color="blue"> "...Customer has picked up a Bluebird or equivalent..." </font>
OK, I'm confused, what is a Bluebird or equivalent and how does it factor into the height of the gate? /forums/images/graemlins/confused.gif
/ The gate #204
Bluebird is a top of the line RV. I've heard they are the very best, which is debatable, but they are very pricey and based on a comercial bus chasis. Half a million bucks to start, with some extreme custom ones for as much as 2 million.
/ The gate #205
Ohhhhhhhhh, don't know why I was thinking in the lines of some sort of tractor/crane equipment, da.
/ The gate #206
Bluebird makes a number of busses, including school busses. I think 30 years ago their motorhomes were top of the line without peer. Today, they're still right up there, although the Prevost conversions just might upstage them a tiny bit. But as has been said, there's no need to go shopping for one unless you have upwards of a half million to spend.
/ The gate
We've got a check, a plan, and now a project, a redo.
Since it's going to start raining tonight I decided this afternoon to pull the gate and overhead.
This is what it looked like first off.
/ The gate
The first thing I had to do was remove the gate.
/ The gate
Then I had to hook up the gin pole and winch.
/ The gate
Then it was hook up to the overhead after removing the plumbing and wiring.
/ The gate
Ready to get out the hot saw.
/ The gate
More of the hot saw's work.
/ The gate
It was getting nigh unto dark. But we got (Iris and me) got the posts ready to dig around and have the crane pull later this week.
We'll keep you posted.
/ The gate
Not quite the same as it was a couple of hours earlier. /forums/images/graemlins/frown.gif
/ The gate #216
Very interesting!
Harvey, what is a hot saw? I saw several of your tools that I would call a hot saw.
Did you make your winch? I think I see another must have tool for building.
/ The gate #217
</font><font color="blue" class="small">( what is a hot saw? )</font>
Don, I think that's the kind of saw that has those two hoses that go to an acetylene and an oxygen tank. /forums/images/graemlins/wink.gif
/ The gate #218
Half the fun of Harvey's posts are his creative use of words and phrases. /forums/images/graemlins/grin.gif
/ The gate
Bird's right Don. A hot saw is a cutting torch.
This is not to be confused with a quicksaw. A quicksaw is a two stroke saw that can have a metal or concrete-rock cutting blade.
/ The gate #220
Thanks, I will add that to my base of knowledge that I'm learning in welding class. /forums/images/graemlins/smile.gif
New 31X13.5-15 NHS tire on John Deere 8-lug grain drill/air seeder rim, Coal Valley, IL (A65640)
New 31X13.5-15 NHS...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
Volvo VNM (A63689)
Volvo VNM (A63689)
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
