The Funnel Bucket
/ The Funnel Bucket #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
I just saw this on a FB group I belong to. Putting this here for discussion. Seems like a really easy build and it seems like it could be a pretty useful tool. I do think its usefulness is greater if used with a CLT or skidsteer. You could make it bolt onto the SSQA plate so you could reuse the plate for other purposes. What to you all think about this?
/ The Funnel Bucket #3
I’m not certain I understand.
I haven’t ever encountered a situation where I couldn’t get the bucket to reach out far enough, but I had vertical clearance.
If it’s intended for a CTL, then I’d think most users would have access or, funds to rent, a mini ex or backhoe and just use the hoe to shovel the material where needed.
It could be nice for backfilling piles or the like, I will say that.
I ain’t saying it’s a bad idea, just that I don’t see how it’s widely practical.
/ The Funnel Bucket
I think it is more for dumping into an area not as wide as a 60" or so bucket. Dumping into a trench, around landscaping, in a single tire track, etc. That is where I see the usefulness.
/ The Funnel Bucket
This one in the picture is a version made by a company. But I think this would be a pretty easy build. As long as you were scooping gravel or dirt out of a freshly dropped pile a regular metal 55 gallon barrel would last a while. Maybe use a big "washer" out of 3/8" steel at the bottom to bolt through and the barrel would last long enough IMO. Or you could get your hands on a chuck of big ol pipe and make it even stronger.
/ The Funnel Bucket #6
I guess you could chain a barrel or pipe to forks and do about the same thing
/ The Funnel Bucket #8
I did exactly that. Only problem was I sued a plastic drum, instead of a steel one. It didn't last but for one job.
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
Bobcat NB160 (A64127)
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
