The Funnel Bucket
/ The Funnel Bucket #1
HawkinsHollow
SE TN
Branson 3015R
I just saw this on a FB group I belong to. Putting this here for discussion. Seems like a really easy build and it seems like it could be a pretty useful tool. I do think its usefulness is greater if used with a CLT or skidsteer. You could make it bolt onto the SSQA plate so you could reuse the plate for other purposes. What to you all think about this?
/ The Funnel Bucket #3
I’m not certain I understand.
I haven’t ever encountered a situation where I couldn’t get the bucket to reach out far enough, but I had vertical clearance.
If it’s intended for a CTL, then I’d think most users would have access or, funds to rent, a mini ex or backhoe and just use the hoe to shovel the material where needed.
It could be nice for backfilling piles or the like, I will say that.
I ain’t saying it’s a bad idea, just that I don’t see how it’s widely practical.
/ The Funnel Bucket
I think it is more for dumping into an area not as wide as a 60" or so bucket. Dumping into a trench, around landscaping, in a single tire track, etc. That is where I see the usefulness.
/ The Funnel Bucket
This one in the picture is a version made by a company. But I think this would be a pretty easy build. As long as you were scooping gravel or dirt out of a freshly dropped pile a regular metal 55 gallon barrel would last a while. Maybe use a big "washer" out of 3/8" steel at the bottom to bolt through and the barrel would last long enough IMO. Or you could get your hands on a chuck of big ol pipe and make it even stronger.
/ The Funnel Bucket #6
I guess you could chain a barrel or pipe to forks and do about the same thing
/ The Funnel Bucket #8
I did exactly that. Only problem was I sued a plastic drum, instead of a steel one. It didn't last but for one job.
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 PETERBILT 579...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
