The Funnel Bucket
/ The Funnel Bucket #1
HawkinsHollow
SE TN
Branson 3015R
I just saw this on a FB group I belong to. Putting this here for discussion. Seems like a really easy build and it seems like it could be a pretty useful tool. I do think its usefulness is greater if used with a CLT or skidsteer. You could make it bolt onto the SSQA plate so you could reuse the plate for other purposes. What to you all think about this?
/ The Funnel Bucket #3
I’m not certain I understand.
I haven’t ever encountered a situation where I couldn’t get the bucket to reach out far enough, but I had vertical clearance.
If it’s intended for a CTL, then I’d think most users would have access or, funds to rent, a mini ex or backhoe and just use the hoe to shovel the material where needed.
It could be nice for backfilling piles or the like, I will say that.
I ain’t saying it’s a bad idea, just that I don’t see how it’s widely practical.
/ The Funnel Bucket
I think it is more for dumping into an area not as wide as a 60" or so bucket. Dumping into a trench, around landscaping, in a single tire track, etc. That is where I see the usefulness.
/ The Funnel Bucket
This one in the picture is a version made by a company. But I think this would be a pretty easy build. As long as you were scooping gravel or dirt out of a freshly dropped pile a regular metal 55 gallon barrel would last a while. Maybe use a big "washer" out of 3/8" steel at the bottom to bolt through and the barrel would last long enough IMO. Or you could get your hands on a chuck of big ol pipe and make it even stronger.
/ The Funnel Bucket #6
I guess you could chain a barrel or pipe to forks and do about the same thing
/ The Funnel Bucket #8
I did exactly that. Only problem was I sued a plastic drum, instead of a steel one. It didn't last but for one job.
40' Shipping Container (A66285)
40' Shipping...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2001 Ford F-550 Flatbed Truck, VIN # 1FDAF56F61ED50387 (A65563)
2001 Ford F-550...
16ft. Field Cultivator (A65640)
16ft. Field...
IRanch High-End Tricycle (A64119)
IRanch High-End...
