The Dreaded oil pan bolt help!
/ The Dreaded oil pan bolt help! #1
BobcatTR
Decatur, IL.
Bobcat CT225
Changed my oil. One of the oil pan bolts doesnt tighten real tight.
The threads on the bolt are fine.
Sooo, I presume my threads are. messed up in the pan.
Any suggestions what I can do to fix it?
Thanks for you help!
Terry
/ The Dreaded oil pan bolt help! #2
Copper gasket for bolt?
Does anyone know what the threads are?
Its a 19mm socket.
Thanks!
/ The Dreaded oil pan bolt help! #5
Terry
Helicoil.
/ The Dreaded oil pan bolt help! #6
Its a 19mm socket.
Thanks!
/ The Dreaded oil pan bolt help! #7
I can tell you Torque should be 29-33 ft lbs. No mention in repair manual of bolt size. Part number is 6697072.
/ The Dreaded oil pan bolt help! #8
I see Dorman makes this...that's when things REALLY get boogered!!!
Boy I hate these metric thread sizes.
And I forgot Bobcat part #'s, are hard to track down.
Thanks for the responses!
The helicoil sounds like a good start!
And Winston I need to remember the torque specs!
Thanks!
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2011 Volvo S80 Sedan (A59231)
2011 Volvo S80...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
