The Dreaded oil pan bolt help!
   / The Dreaded oil pan bolt help! #1
BobcatTR
Decatur, IL.
Bobcat CT225
Changed my oil. One of the oil pan bolts doesnt tighten real tight.
The threads on the bolt are fine.
Sooo, I presume my threads are. messed up in the pan.
Any suggestions what I can do to fix it?
Thanks for you help!
Terry
   / The Dreaded oil pan bolt help! #2
Copper gasket for bolt?
Does anyone know what the threads are?
Its a 19mm socket.
Thanks!
   / The Dreaded oil pan bolt help! #5
Terry
Helicoil.
   / The Dreaded oil pan bolt help! #6
Its a 19mm socket.
Thanks!
   / The Dreaded oil pan bolt help! #7
I can tell you Torque should be 29-33 ft lbs. No mention in repair manual of bolt size. Part number is 6697072.
   / The Dreaded oil pan bolt help! #8
I see Dorman makes this...that's when things REALLY get boogered!!!
Boy I hate these metric thread sizes.
And I forgot Bobcat part #'s, are hard to track down.
Thanks for the responses!
The helicoil sounds like a good start!
And Winston I need to remember the torque specs!
Thanks!
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
205196 (A52706)
205196 (A52706)
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
