The Dreaded oil pan bolt help!
/ The Dreaded oil pan bolt help! #1
BobcatTR
Decatur, IL.
Bobcat CT225
Changed my oil. One of the oil pan bolts doesnt tighten real tight.
The threads on the bolt are fine.
Sooo, I presume my threads are. messed up in the pan.
Any suggestions what I can do to fix it?
Thanks for you help!
Terry
/ The Dreaded oil pan bolt help! #2
Copper gasket for bolt?
Does anyone know what the threads are?
Its a 19mm socket.
Thanks!
/ The Dreaded oil pan bolt help! #5
Terry
Helicoil.
/ The Dreaded oil pan bolt help! #6
Its a 19mm socket.
Thanks!
/ The Dreaded oil pan bolt help! #7
I can tell you Torque should be 29-33 ft lbs. No mention in repair manual of bolt size. Part number is 6697072.
/ The Dreaded oil pan bolt help! #8
I see Dorman makes this...that's when things REALLY get boogered!!!
Boy I hate these metric thread sizes.
And I forgot Bobcat part #'s, are hard to track down.
Thanks for the responses!
The helicoil sounds like a good start!
And Winston I need to remember the torque specs!
Thanks!
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
2023 Ranger 1000 XP North Star (A62679)
2023 Ranger 1000...
90in. Work Bench (A65640)
90in. Work Bench...
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
Toro LX460 Riding Mower (A65579)
Toro LX460 Riding...
