That Never Ending T&T Path!
/ That Never Ending T&T Path!
<font color="blue"> If you do not use this setup some where down the road the restricted flow will cut a hole in the hose. </font>
CCI,
Interesting observation! I can see how that might possibly happen. Do you have any idea how often such an event might happen? I would guess it is rare, but who tracks these things anyway?
I for one will certainly keep this thought in mind in case I apply orifice flow restrictors to something in the future.
Thanks for mentioning it. First I have heard of this possiblility.
/ That Never Ending T&T Path! #102
We noticed this problem in 1994 on V-Rakes. All of a sudden after half a season of use 30 rakes had hoses with holes in them all close to the same spot. These were on hoses leading to 2"x 10" hydraulic cylinders. Usually rakes are raised at the end of the field as the operator is turning around.
/ That Never Ending T&T Path! #103
Mark,
Thanks for pointing that out. I have never encountered that problem, having used very few restrictors of that type. Thanks again for the tip.
<font color="blue"> It is not the way Bill did it but the most common way to retain the couplers are external snap rings. The quick connectors already have the ring grooves. </font>
Jerry,
I have heard of snap rings being used but have not seen a picture and don't know how it would be done with the parts I used.
Attached is a more detailed photo of my setup. Are these quick connects different from what would be used if snap rings were used to secure them?
I used a lock washer under the jam nut on the bulkhead fittings, and a touch of "PineRidge blue" to mark the holidays. /forums/images/graemlins/grin.gif
HAPPY HOLIDAYS EVERYONE!
/ That Never Ending T&T Path! #105
Henro I couldn't make sense out of it until you mentiond the bulkhead jam nuts in an earlier post, then it came together for us. Thanks for posting that close-up shot, and it's OK to use a little blue on your Kubota. /forums/images/graemlins/wink.gif
/ That Never Ending T&T Path! #106
<font color="blue">I have heard of snap rings being used but have not seen a picture and don't know how it would be done with the parts I used. </font>
Bill,
If you will look at the body of the female half of you quick connector, you should see small grooves. These grooves are for external snap rings. The distance between the grooves defines how thick the mounting bracket needs to be.
/ That Never Ending T&T Path! #107
Hi Guys,
Just wanted to thank you for the very informative postings and kudo's to you Henro for an excellent job on the TNT and the how to too /forums/images/graemlins/wink.gif
But my toy err tractor is <font color="blue"> BLUE </font>, so I was wondering if there are any TC30 owners out there who have done or are planning on doing TNT, and what their results/thoughts are.
Not trying to start a brand war here, just an observation, but there are apparently some differences in the hitch linkages from orange to blue and I'm curious as to how they affect the design process. For instance my lift links have swivel eyes in the top end, I'm not sure how the Kubota model deals with those variations in geometry. I'm sure there are other differences I haven't noticed and perhaps I'm making mountains outa molehills but I'm curious, and at the prices some have quoted for dealer installed, well dyi would come close to paying for the welder to do it with and maybe even a few other toys/tools.
TIA
Dart
/ That Never Ending T&T Path! #109
test
Very wierd look at the date of this post made on 5/3/05
/ That Never Ending T&T Path! #110
Bill,
You truly are an artist! Excellent workmanship with the hitch and all the photos and postings! I love the clever way you concealed the oops holes. That's a neat installation with the valves overhead. I guess the only thing we could ask for is action photos now! /forums/images/graemlins/grin.gif
Thanks guys! I guess this thread popped up again because I referred to it in another thread...
<font color="blue"> Very wierd look at the date of this post made on 5/3/05 </font>
Mike...
I just looked...it says 05/03/05...May 3, '05 ... did it say something else when you posted?
HobbyFarm,
I am really happy with the T&T. I do like having the two cylinders for tilt, although it may not be necessary on larger tractors. I do use and like having float on one cylinder too. I use it a lot. It helped with my backblade on snow and also with my rake on the driveway. One of the neatest uses of the tilt is when using the PHD, when the tractor is on an angle. I can now get the auger truly vertical (more or less) in an instant...
The valve being up in the air has not been an issue so far. I am still undecided about it though. I will know more after a year goes by. I do like it up there out of the way. But I would certainly not put one up there if there was only a ROPS and nothing else...That would look wierder than PineRidge's date... /forums/images/graemlins/grin.gif
/ That Never Ending T&T Path! #112
Bill it may have just been a senior moment, sorry for the bother.
/ That Never Ending T&T Path! #113
Mike, I thought I was having a premature senior moment when I read your post. I just figured it must be over my head and I was not going to understand it no matter how hard I tried.
/ That Never Ending T&T Path! #115
I'm sure all men here had a double take on that Fine Rear End!!!
/ That Never Ending T&T Path! #116
My tilt cylinders ended up being about an inch shorter than the length of the fixed lift rod on my B2910. That and the retract capability of the top link resulted in the rear blade being held up off the ground when the 3PH is fully raised and the top link is fully retracted.
I am hopeful that the net result is that when I have my post hole digger on, I will have a little more lift. As is(was) I have(had) about 4 inches clearance between the auger tip and the ground. I am hopeful that I will have double that now. A one-month loan of the post hole digger to a friend is stretching out to six months now. I guess I will find out in the spring. I also think I will stop loaning things to people.
I would t loan my son my tractor!
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
(4) Wheels and Tires (A65640)
(4) Wheels and...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
70in. Skid Steer Root Rake (A65640)
70in. Skid Steer...
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
213324 (A64279)
213324 (A64279)
